Ignition for 400whp
Old Nov 8, 2008 | 09:54 PM
TURSTY's Avatar
The wankel way!!
Ignition for 400whp
Hay guys,
About to have the car retuned to about 400whp when I install the new fuel system and am wondering what I need to do to the ignition to support this power level?
Car:
FD street port 13B
single turbo,
PFC
All supporting mods
Old Nov 8, 2008 | 11:27 PM
cewrx7r1's Avatar
Eye In The Sky
Some have done it with the stock ignition. I have the HKS Twin Power. Many also use Crane or MSD boxes. Any good ignition amp will do and only needed for the leading plugs for 400hp.
Old Nov 9, 2008 | 12:30 AM
thewird's Avatar
A lot of people are using the HKS Twin Power with success are various power levels and I have never heard of one fail. I'm also using a Twin Power.
thewird
Old Nov 9, 2008 | 08:21 AM
IAN's Avatar
IAN
Rotary Reborn!
I am considering autronic 500R. Well have been for like two years.
Currently 400rwhp with FJO injection without any ignition amps. 19psi with no issues. But to be safer I will be getting something. (Eventually)
Ian
Old Nov 9, 2008 | 08:33 AM
R-R-Rx7's Avatar
Rotor or no motor
im using a twin power too and im happy asweel
Old Nov 9, 2008 | 09:12 AM
oo7arkman's Avatar
In the Garage
On the stock ignition I had a bit of breakup at high rpm at 17psi. Now with the twin power I have no more problems with breakup. I see a little over 400whp at 15psi.
Old Nov 10, 2008 | 12:30 AM
szalony's Avatar
DORIFTUUUU MASTAHHH!!!
Yeah Dood!
Old Nov 10, 2008 | 10:23 AM
zinx's Avatar
_________________________
Try stock first, if it breaks up get a twin power. No need to speed a bunch of time and money on the FD's ignition for 400 rwhp.
Old Nov 10, 2008 | 03:58 PM
thewird's Avatar
If your aiming for 400 rwhp, it seems silly to skip out on a such an important piece like the twin power which is only $300-$500 depending on where you get.
thewird
Old Nov 10, 2008 | 04:25 PM
Jacobs is treating me very nicely. Great amp for the money.
Old Nov 10, 2008 | 05:00 PM
oo7arkman's Avatar
In the Garage
thewird
Exactly.. Not to mention with the optional wiring harness ( I also advise you buy) the most time consuming part of the install is just figuring out where you want to mount it. It is so very simple to install, and it is proven to work.
Old Nov 10, 2008 | 07:49 PM
darkphantom's Avatar
The king of the highway!
msd 6al. powerful enough to support 600hp
Old Nov 10, 2008 | 08:04 PM
TweakGames's Avatar
FD pro licensed driver
I am NOT saying that the twin power doesn't work, but I am a little confused. If it has been proven that all it does is strike twice at lower RPMs, and increase dwell at higher, wouldn't a standalone that allows someone to set dwell times do just as well for the higher rpm (where ignition is a problem)?
Old Nov 10, 2008 | 08:13 PM
the only reason Tweakgames is that anything over 450hp and that twinpower really isnt efficent. when steve kan came here to FL and alot of the people who had there twin power started blowing like skies. and it wasent pretty.
So
300-430 (safely) HKS twin power
430-490 (safely) Jacobs FC2000
500-600 (safely) MSD 6al
600+ & your going to need upgraded coils, distributors, wires, and another msd 6al box
but you choose, its your money afterall
I was here when steve kan tunned and 20% actually got there cars tunned without blowing something!
Old Nov 10, 2008 | 08:37 PM
arghx's Avatar
rotorhead
its a mixed bag on the twin power. for some reason an MSD 6AL box on the leading didn't work well for me (stock FC coils) and the twin power worked very well for a low 400whp setup. I've met a guy with a 600whp Supra running a twin power on stock coils. But I've also heard of the twin powers overheating (could also depend on engine bay placement) and oozing black gooey stuff.
Old Nov 10, 2008 | 08:48 PM
thewird's Avatar
Just make sure the twin power is in a place it gets airflow and isn't close to the engine or a heat source.
thewird
Old Nov 10, 2008 | 09:23 PM
/\ yes
Old Nov 10, 2008 | 10:10 PM
cewrx7r1's Avatar
Eye In The Sky
The Jacobs has been known to burn out stock FD primary coils. That is why some of us use the FC leading coil on or FDs even if not running a Jacobs.
HKS now states that the TWINPOWER is made to work with resistor plugs. Previously they did not say that and many of us ran non-resistor plugs.
Luckily, I always mount my equipment in the coolest posible places. Must be my prior 7 years electronics experience in the USAF saving my butt more than once.
Any way this is the first time I heard of Steve burning up TWINPOWERS.
Old Nov 11, 2008 | 07:18 AM
/\ thats what happened to me. when we made 478 the jacobs ignition popped on us so bad that it left a dent in the hood. so i went with the msd and im happy now
Old Nov 11, 2008 | 08:32 AM
zinx's Avatar
I'm making 512 and have a stock ignition with a twin power. Never had a problem in the two years i've been at this power level, or the 3 years before that where i was just a bit over 400. I have friends making over 500 as well with just a twinpower without any trouble.
Old Nov 11, 2008 | 09:05 AM
gusfd3s's Avatar
E85 Addict
548whp here with twin power. Never had a problem with mine.
Old Nov 11, 2008 | 09:17 AM
dregg100's Avatar
if i remember correct, there was a guy that put down ~620 with stock coils and a twin power.
Old Nov 11, 2008 | 12:48 PM
philiptompkins's Avatar
could someone explain dwell times to me?
I remember I had them set up incorrectly in my megasquirt and it woulden't rev over like 5500 rpm.
Old Nov 11, 2008 | 02:46 PM
allright, let me revise my quesiton: What effect does dwell have on tuning?
Old Nov 11, 2008 | 07:33 PM
TURSTY's Avatar
The wankel way!!
I think I'll be looking into the MSD 6al. There about $300 cheaper then the HKS Twinpower over here.
I can also get my hands on a new MSD 6al2 for a good price. Can the duel stage rev limiters be used in rotarys? (excuse my ignorance)
