93 only boosting 5lbs experienced help needed
Old May 14, 2002 | 10:59 PM
autospot's Avatar
workaholic
my 93 touring is only boosting 5lbs. and is bucking and jerking missing etc. i was told that it was a boost leak so i tightened down the clamps and yes they were a little loose . Its running better but 2nd turbo still isnt coming on should i check the y pipe are there any tests that i can do to find a boost leak whats going on with this car if you have the cure let me know PLEASE thanks greg ps. turbos are new 6k on them and it has a blitz air intake
Old May 14, 2002 | 11:09 PM
P'cola FD's Avatar
Hamado things my way!
Look at my post about boost leaks here https://www.rx7club.com/forum/showth...ight=boost+leak
Old May 14, 2002 | 11:42 PM
P'cola FD's Avatar
Since the link doesn't work, here is the procedure:
More than likely you have a boost leak somewhere. I've found that the best way to find boost leaks is to take some soda cans or tennis ***** or anything of the like, and put them in the intake hoses(from the airbox to the turbos). Clamp the hoses tightly around the cans. Next, get a blower nozzle for an air compressor that can have a vacuum hose slip on. Put the vacuum hose on the blower nozzle at one end and an intake nipple at the other end. Tighten the vacuum hose down with hose clamps at both ends. Turn the car on(not the engine though). Now lightly blow air into the intake with the blower. The air will have no where to go except where the leak is.
