Found oil in odd spot.
Old May 14, 2002 | 05:48 PM
Rx-7$4$me's Avatar
well.. today in auto's class I lifted my car up and found that right next to the oil pan bolt, there was a small hoze and a thing that looked like a fuel filter with oil all over it... it wasnt dripping but it was on there.... anyone know what im talking about? its directly right next to where the bolt is in the oil pan to drain the oil...... my turbo's are working fine at around 11-8-11 pattern.... car pulls strong... no smoke from burning oil... any ideas why its there?
Stevo
Old May 14, 2002 | 05:49 PM
Rx-7$4$me's Avatar
forgot to say... 93 fd 71xxx miles on original engine.
Old May 14, 2002 | 11:18 PM
Rx-7$4$me's Avatar
b U M P
Old May 14, 2002 | 11:29 PM
A-Spec Tuning's Avatar
Registered User
thats the turbo control actuator..check for oil leak right above it... ie: turbo assembly
Old May 14, 2002 | 11:31 PM
stevecod's Avatar
Re: Found oil in odd spot.
Stevo
well, for sure it's not your fuel filter because the fuel filter is way in the back and way up there between the diff. and the fuel tank.
Old May 15, 2002 | 04:28 PM
twinturborx7pete's Avatar
Juris Doctor
My car is also leaking a tad bit of oil, only when it is hot, when the car is cold the car doesn't leak oil... odd enough..??
Anyways its really hard to find, seems to be coming from the driver's side somewhere, because i can sometimes see it drip off of the control arm.. like it is running down... i'm starting to think maybe it is my oil sending unit?
Old May 15, 2002 | 04:33 PM
cymrex's Avatar
Check the turbo oil return lines. Often one of them is leaking and it could easily get all over the actuator. There is one oil return line per turbo so check all 4 seals for leakage.
Queppa
Nov 18, 2024 03:47 AM
Th0m4s
Feb 26, 2019 02:04 AM
Microtech
30
Apr 23, 2016 06:37 PM
immanuel__7
89
Sep 5, 2015 10:23 AM
