Sad Panda :(
I officially put away my 7 for the winter today. She's sitting about 5 minutes from my apartment in a buddy's dirt floor garage on jack stands. Coolant is drained and one gallon of straight antifreeze in so my block doesn't crack like the guy from Alaska's did last winter. Unhooked my battery. The worst part about it is I didn't even get to go for one last good drive as my slave cylinder died on me overnight last week. I'm looking forward for May when she'll be out and about again.
Hey Whitey.... Just a note here; since it is stored on a dirt floor you should lay some plastic sheeting under the car. This will prevent moisture from rising from the dirt, increasing the rate of rust development. If it was concrete, then this would not be necessary, but since it is dirt, do yourself a favor.
Trending Topics
Solid advice, my "shop" has a dirt floor and the bottom of the car gets nice and damp on the humid days, really sucks. Won't be much longer before I stop driving my FB's for the winter as well, so I feel your pain whitey....
I still have the 89 vert on the road and will probably drive this week and next ..... still no snow in the forcast ( so NO chance road salt ) Supposed to be sunny and about 5-10 celcius (40 - 50 Farenheit) all week . Probably take her to work tomorrow .
I feel the pain on the 79 though , she's tucked away with some fuel stabilizer and a dust cover till April.
lol, the air gets so dry up here and it stays well below 20*F all winter, so it shouldn't be *too* bad on the dirt, but it's not worth the risk of coming back in the spring and finding some bad rust.
search for 49930 on maps.google.com if you wanna see where my car is located for the winter.
This will probably be the last winter I'll drive my SA. Since it's starting to get colder and it could start snowing soon I'll be swapping out the Libra's/Sumitomos for the stockers for the winter.
https://www.rx7club.com/forum/showthread.php?t=586025
Car storage How-2
since you poor bastids are now starting to see hints of winter -
which arrived a here a MONTH ago !
;P
Oh, and Kentetsu, many concrete floors weep moisture almost as bad as dirt floors -
lay a piece of plastic down for a few weeks, you'll likely see moisture collecting underneath!
Stu Aull
80GS-under-a-foot-of-snow
Alaska
Car storage How-2
;P
Stu Aull
Alaska
On a related note I'm at work right now, and its snowing like a blizard out here, I didn't think it was cold enough but its actually sticking, of course I drove one of the 7's today too haha, oh well...
I hope you put something under the jack stands, to keep them from sinking into the dirt. It does not matter how well packed the dirt seems, jack stands will slowly sink as the temp fluctuates. Next spring, your car could be sitting on the dirt, with buried jack stands under it......
You should be using a 50/50 mix of antifreeze, not 100%. I would also fill the cooling system to the top so as to not leave any of it exposed internally or it could rust or corrode.
I'm going to fill it 70/30 because it will get down to -40 for at least a week this winter.
fortunately it hasn't started snowing yet in Idaho...but i'm still deciding on if i plan on driving it in the snow...seeing as how i am putting mud flaps on the bad boy...put'em to use i suppose...depends on if they use sand, or salt around here on the roads,
If it gets as cold as it does here in Idaho (i'd think it does because we have Superior to keep us kinda warm), i think that they'd use sand like they do here.
