Tips for bushing install
Old Oct 24, 2008 | 08:21 PM
jmw23712's Avatar
Anyone have any tips or advice on how to press the Superpro urethane bushings in the toe links. The urethane bushings have a lip on each side and they will not press in. Could I slit them down the middle like some of the other companies 2 piece bushings?
This is the kit I ordered:
http://shop.jklre.com/products/fd-sp-bushings
I got my old rubber bushings out with no problems, but I can't get the new ones back in. Any advice? Thanks
Old Oct 25, 2008 | 12:15 AM
2007 ZX-10's Avatar
buy a 20 ton press...they will go in
Old Oct 25, 2008 | 10:22 AM
caredden's Avatar
Super Moderator
Veteran: Marine Corp
Not toe link related, but Superpro related. This thread talks about the Superpro diff bushings. Check out post #11.
https://www.rx7club.com/showthread.p...=diff+bushings
good luck,
Charlie
Old Oct 25, 2008 | 01:48 PM
RIX-7's Avatar
install
On my lower front strut bushes,I used some pipe cut to half the length of the bush.A long bolt and big washers,use the pipe as a sleeve and the bolt to pull the bush through,Soap to lube it.Works great on the small bushes,And then use the bolt to pull the inserts through.
rotor_veux
46
Jun 12, 2018 10:39 AM
roondawg
Aug 24, 2015 04:43 PM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
