want to make 300-350hp w/ carbed 2nd gen
Old Oct 23, 2008 | 10:00 PM
andresj's Avatar
bone stock
Hey I have a street ported 2nd gen with Weber carbs 48dcoe. I was wondering what turbo i should go with to get around 300-350hp. My car is set up mainly for drifting if it helps making the decision. also if there is any companies out there that make kits for this? your help will be greatly appreciated.
Old Oct 23, 2008 | 10:16 PM
TweakGames's Avatar
FD pro licensed driver
Old Oct 23, 2008 | 10:18 PM
andresj's Avatar
bone stock
Originally Posted by TweakGames
thanks anyone else? if it's a dumb question just ignore this thread and continue on with your life.
KhanArtisT's Avatar
Former FC enthusiast
BNR stage 2 can get around those power levels I believe.
Old Oct 23, 2008 | 10:19 PM
andresj's Avatar
bone stock
alright cool thank you I'll look into those
Old Oct 23, 2008 | 11:01 PM
TweakGames's Avatar
Sorry, I posted in the wrong thread and couldnt delete it. hehe.
Old Oct 23, 2008 | 11:15 PM
Frostycrowd's Avatar
are your webers boost prepped? but a BNR would do the trick.
Old Oct 23, 2008 | 11:26 PM
andresj's Avatar
bone stock
yes they are
Old Oct 24, 2008 | 08:57 AM
moremazda's Avatar
Gone Race'n
Do your self a favor an go for a four barrel carb over the two barrel. It will make life much easier when it comes to to making the car acctually driveable.
The problem with the two barrel is that it has one fuel circuit that needs to operate in two very different "atmospheres". The first atmosphere being the one that you are breathing right now with 14.7psi (absolute) in the fuel bowl and then the full power atmosphere (14.7+boost). From my experience if you keep the boost below 8-10psi you can acctually make the carb work, and work pretty well, you may not like the gas mileage but it will work. With the four barrel you have an additional fuel circuit to work with in the tuning.
Old Oct 24, 2008 | 09:08 AM
andresj's Avatar
bone stock
yeah thanks i was told before to keep the psi under 10 if i were to turbo my car the way i have it now. and as for gas mileage OH WELL
Rotospectre
Mar 28, 2018 03:33 PM
lt1_rx7
Blue Ridge Rotary Run
46
Oct 9, 2015 03:11 PM
wallyrx7
Rotary Car Performance
Aug 20, 2015 05:55 PM
