T78 Questions
Old May 14, 2002 | 10:22 AM
lerch32's Avatar
T78 Questions
Can you run the set up without a ported motor, and please list everything that you would need to run the setup. I allready have the T78 kit. O ya it's for a FD. Can you run it with PMS. I need to know about fuel, what size injecters, and so on. Thank you for any help.
Old May 14, 2002 | 11:08 AM
13BAce's Avatar
On a long vacation
You can put it on a motor that isn't ported, but you may not have the top end power that a ported motor would have. That turbo has ALOT of good top end power.
I believe that Jason was running a PMS with his T-78. You'll need 1200 cc secondaries, but that may not be enough if you plan on alot of boost. If you ran the 850's as primaries as well that should help, but I don't know much about the PMS and if it can handle that.
You'll just need the usual mods: Fuel pump and injectors, full exhaust, front mount intercooler, etc.
Old May 14, 2002 | 11:11 AM
lerch32's Avatar
Thanks buddy, I will ask Jason.
Old May 14, 2002 | 11:13 AM
lerch32's Avatar
I plan on about 15 lbs of boost. I want just over 400 rwhp.
Old May 14, 2002 | 11:58 AM
13BAce's Avatar
On a long vacation
550's and 1200's may be pushing it. 850's and 1200's should work, but 1600's would give you a little more headroom than the 1200's. The downside is that you'll need a new fuel rail.
_Tones_
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
