Someone please enlighten me as to what these connectors are for?
Old Oct 22, 2008 | 09:58 PM
apeiron
Exclamation Someone please enlighten me as to what these connectors are for?
I am pretty sure that the small black connector is for the fan relay mod that makes them run for 10 minutes but I am not positive on this. What is the larger black connector for?
I have my harness on the left for comparison.
Any help will be appreciated
Attached Thumbnails Someone please enlighten me as to what these connectors are for?-help.jpg
Old Oct 22, 2008 | 10:02 PM
Mahjik's Avatar
Mr. Links
Fan control box from the cooling system recall, which should be on the stock ECU bracket. I'm not sure you need it if you have a programmable ECU.
Old Oct 22, 2008 | 11:49 PM
apeiron
Hmm... This is a definite concern for me
I found your old post @ https://www.rx7club.com/showthread.p...an+control+box , you seemed pretty certain on your answer so it sounds like I have a recall harness, can I leave this hookup disconnected then?
Old Oct 23, 2008 | 08:42 AM
Mahjik's Avatar
Mr. Links
If you have a PFC, you can use the Datalogit to program when your fan come on.
Old Oct 23, 2008 | 11:02 AM
apeiron
So the recall fan mod is essentially useless w/ a PFC then?
Old Oct 23, 2008 | 11:15 AM
Mahjik's Avatar
Mr. Links
Yes
