87 RX7 Has raw fuel coming out
Old Oct 20, 2008 | 05:52 PM
Neophean's Avatar
Hey everyone quick question.
I started my RX the other day and its been starting fine.
Until yesterday. I think I flooded it. Normal... But still wont start 30 hours later.
I have done everything from taking out the spark plugs etc. but I did notice that there is fuel leaking from under the car right by where the exhaust pipe meets the cat? Is it just that my car is just that flooded or is it something else? If so what and how should I go about fixing this problem??? And help would be great.
Thanks
Brandon
Old Oct 20, 2008 | 06:44 PM
RotaryRocket88's Avatar
Top Down, Boost Up
If there's a big fuel leak, you might not even have enough fuel pressure to start the car. Nevermind the fact that you can set the car on fire if you leave it. Fix the leak.
Old Oct 20, 2008 | 06:54 PM
WingsofWar's Avatar
The Firestarter
pulsation dampener gone
Old Oct 21, 2008 | 10:25 AM
Aaron Cake's Avatar
Engine, Not Motor
It's possible you have an injector locked open. If the fuel is actually coming from between the turbo and engine through the gasket, then I'm willing to bet that's the case.
But check the pulsation damper first. A leaking damper however will not prevent a car from starting.
Old Oct 22, 2008 | 11:12 AM
Neophean's Avatar
Well went out today to try and work on the car, blew the starter.
I've had enough if anyone is intrested in parts let me know as I am just going to part out the whole thing.
Old Oct 25, 2008 | 11:15 AM
Aaron Cake's Avatar
Engine, Not Motor
All you need to do is replace the offending injector.
How you managed to blow a starter I don't know. The Mazda starters are damn near bulletproof.
Old Oct 25, 2008 | 12:11 PM
S4GXL's Avatar
yeah no kidding you are dealing with piddly issues, especially with a rotary. fix it and keep rocking it. or sell it dont part it out.
Old Oct 25, 2008 | 02:00 PM
freemanrx7's Avatar
^Hold On
Take the pulsation dampner of and replace. While there have the fuel injectors sent out and cleaned. Put back together and put little bit of oil in the rotor housing then fire up. If you have to-- replace the starter and clean the contacts. This all could be done for a for around $200-$400.
You could find a used pulsation dampner pref S5?
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
