Broken drivers side motor mount - best alternative?
Old Oct 17, 2008 | 11:57 PM
apeiron
So after pulling my engine out and swapping parts over to the new engine I discovered that my drivers side motor mount was split in two. What is the best alternative for me to go with if I do not want to use the OEM motor mount as a replacement
Old Oct 18, 2008 | 12:48 AM
alexdimen's Avatar
TANSTAFL
I had this question too. The answer was to search.
Old Oct 18, 2008 | 12:11 PM
apeiron
I've searched and I am aware of the options but I do not know who to go to to order from.
I understand Banzai has some but I was following up a thread in regards to a forum member named Scalliwag who apparently made some that people seemed to like. Not sure if I can get my hands on a set of his or not.
Old Oct 18, 2008 | 12:36 PM
akiratdk's Avatar
The Laser Man
I just bought some poly mounts from banzai racing~
They are simple and very straight foward to replace.
But at the same time if you are replacing the motor mounts might as well at the same time put an oil pan brace at the same time~ it will help ya in the long run.
