Some questions on FD
Old Oct 16, 2008 | 11:33 PM
nickk47's Avatar
Boost Spike
Is there any way to lower the car without getting aftermarket springs?
Do I really need to upgrade the stock front/rear anti sway bars even if the car is used as a daily driver?
Do I need a dual or single aftermarket oil cooler ? ( Is it highly recommended?)
Old Oct 18, 2008 | 05:26 PM
dgeesaman's Avatar
1) No
2) No
3) Only if you're doing serious track stuff.
Old Oct 18, 2008 | 05:57 PM
nickk47's Avatar
Boost Spike
Thanks for the answers~
Old Oct 18, 2008 | 06:07 PM
userjh5174's Avatar
You could also cut a few coils of your springs to lower the car, if you just want the look. I would get proper shocks/springs for a safe operation.
Old Oct 18, 2008 | 09:39 PM
dgeesaman's Avatar
You could also let most of the air out of your tires if you want low profile look, but that doesn't make it safe or effective.
Dave
Old Oct 18, 2008 | 10:19 PM
DriftDreamzSS's Avatar
just fill your car with all the heaviest stuff you own, it will sit lower and look really awesome.
Old Oct 19, 2008 | 03:09 AM
nickk47's Avatar
Boost Spike
umm but that will increase weight...nvm I am planning on buying some springs.
_Tones_
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
