Proper method for testing spark?
Old Oct 16, 2008 | 05:27 PM
sbnrx7's Avatar
I need to test my spark plugs and have read the proceedure outlined in the FSM on page G-18. But the proceedure doesn't mention anything about disabling the fuel system or unpluging the other plug wires from the coils during the test. So what is the right way to do it?
Steve
Old Oct 16, 2008 | 08:23 PM
GreatShamanGT's Avatar
Roxann7
What I did was just buy some new spark plugs, and then hook them up to one of the coils while I cranked the car and grounded the plug.
Old Oct 16, 2008 | 08:29 PM
sbnrx7's Avatar
It didn't flood your engine?
Old Oct 16, 2008 | 08:34 PM
Roxann7
It didn't flood mine. Or you could just take out the spark plugs and then do what I did.
Old Oct 16, 2008 | 09:11 PM
sbnrx7's Avatar
I guess I need to correct my original post. The purpose is that I want to test each coil and not necessarily the spark plugs. I'm trying to find out which, if any, of my coils are bad despite the bench test results I got in which I measured ohms of resistance per the FSM. So I want to test the spark at each coil and thought this would be the best way.
Old Oct 16, 2008 | 09:15 PM
IRPerformance's Avatar
Sponsor
Get an inline spark tester. It is basically a short spark plug wire with a light that plugs between the spark plug and the wire. When the coil fires, the light comes on. You can run the car with it hooked up.
Old Oct 17, 2008 | 01:17 AM
bowlcutsaresweet's Avatar
If your worried about flooding your engine, pull out the EGI relay.
rgordon1979
40
Mar 15, 2022 12:04 PM
ZacMan
Sep 19, 2015 09:20 PM
Enzo1944
Sep 6, 2015 08:57 AM
ZaqAtaq
Sep 5, 2015 08:57 PM
