Need some help
Old Oct 15, 2008 | 08:38 PM
jake1191's Avatar
Pop Pop BANG FIRE!
Need some help
Just bought an 88 Vert Rx-7 N/A. I ordered new struts but want to do the car right and get some aftermarket springs but im on a tight budget. I also have a leaking fuel injector or so im told. The car doesnt start like 2 hours after it has been driven. Is this a leaky injector or something else?
Old Oct 15, 2008 | 08:40 PM
87 t-66's Avatar
not a drifter
sounds like it, or the engine is flooding from some other reason. i would put money into making the car reliable and safe before buying aftermarket suspension parts.
Old Oct 15, 2008 | 08:44 PM
jake1191's Avatar
Pop Pop BANG FIRE!
its definetly reliable other than the injector problem and if i get new ones it will be in a month. i just changed all the fluids, fuel filter and all that stuff so that much is ready to go.
Old Oct 15, 2008 | 08:58 PM
87 t-66's Avatar
not a drifter
there are some good places that will clean/flow test your injectors for about $15-$20 each. i have had good results from witchhunter. some flooding problems are caused by low compression but hopefully its just an injector.
