simple way to find exhaust leaks?
Hello. I swear I have an exhaust leak somewhere between my engine and my t04s that I can hear, I just can't seem to find it. Is there any tips or tricks you guys have to find super ninja exhaust leaks?
I was thinking about doing what I do to find vac leaks: Wait for the exhaust to cool then spray it with soapy water, and then use my air compressor to pressurize the exhaust from the muffler. Does anybody see any reasons why this wouldn't work?
Thanks
~Tweak
Thanks
~Tweak
Just start the motor up cold and move your hands over every possible spot. You will have a little bit of time before its too hot to feel every area. Easiest way to do it..
Trending Topics
Idle the motor. Use a rag or a thick glove to close off the tail pipe and listen for puffing sound. I have done this many times and can judge the size of the leak by the backpressure against my hand over the tailpipe.
I have heard of shaking a feather duster covered in talcum powder along the exhaust system. The bypassed air will blow the dust making the leak visible.
If you want to do it with the car off you can implement some dry ice and a small vac set on reverse. It will push the mist into the exhaust and come out the leak. The quickest and simplest way is to just put the car up on a lift or jack stands and feel for the exhaust air pushing out.
Get a long screwdriver or a peice of wire, tape a thin piece of paper/tissue to the end and l hoover paper end close to all possible areas, the paper will flutter where ever the leak is.
alphawolff
Nov 17, 2015 05:57 PM
