Megasquirt ms 1 on a fd
Old Oct 12, 2008 | 08:55 PM
elturbonitroso's Avatar
CT ms 1 on a fd
can i use a ms1xtra with the stock trigger wheel and coil or do i have to swap in a cas from a fc motor any info its apreciated.
Old Oct 13, 2008 | 10:09 AM
Aaron Cake's Avatar
Engine, Not Motor
You can use the stock triggers as they are the same as the FC (almost).
If you want to swap the FC CAS in place you need to also swap the FC front cover which will add extra complications.
Old Oct 13, 2008 | 05:15 PM
ok so the trigger angles set ups are the same also the pullup resistors on the leds
Old Oct 13, 2008 | 05:51 PM
muythaibxr's Avatar
MegaSquirt Mod
I had an FD starting up on ms1 using the exact same trigger wheel settings I used for an FC. However, I changed the outputs to "FD" style in the settings.
Ken
Old Oct 14, 2008 | 09:16 AM
Aaron Cake's Avatar
Engine, Not Motor
What he said.
The FD trailings are different then the FC trailings. You need to make sure "FD trailing" is set up in the split section.
