Boost controller HKS EVC EZ VI
Old Oct 10, 2008 | 03:14 AM
pietrino's Avatar
Italian Rider
Question Boost controller HKS EVC EZ VI
Hello, question about install.
Should i keep the restrictor pills for wastgate and turboprecontrol??
How didi you installed your boos controll system?
i connected the boost controller via 2 Y connector (one to connect the wastgate and turboprecontrol fron2 to 1 line to the boost controller and the other to split again fron 2 to 1 to close the line). Then i close both line of the wastgate and turboprecontrol of the other side (the side of the driver)
During the first install, in the little computer of the Boost controller, he ask me wich is the standard boost for RX7, shoult i put there 0,75 bar? and swing ported and then 4cylinder??
Thanks
Pietro
Old Feb 4, 2009 | 06:59 PM
Force13B's Avatar
No more G6
The passanger side of the wastegate controller and turbo precontroller should be T together and go into your boost solenoid sensors. The drivers side should be caped.
Stock boost for the rx7 is 10psi or 0.689bar. I have mine set to 0.70.
Old Feb 7, 2009 | 08:37 AM
pietrino's Avatar
Italian Rider
thanks, but shoul i remove the restrictor pills between Wastgate and bosst controller solenoid????
Old Feb 7, 2009 | 09:25 AM
DaleClark's Avatar
RX-7 Bad Ass
Always remove the restrictor pills. They are only for use with the stock boost control solenoids, that's it.
Dale
Old Apr 14, 2009 | 04:38 PM
pietrino's Avatar
Italian Rider
Another little questions, in the beginning setting, when it ask wich is the stock boost shoult i put 0.75 bar? I don't know how much PSi it is
Thanks
Pietro
I just selected 0.85 Bar and it limit to 0.6, should i incrase at about 120% in the varous setting?
Thanks
