Megasquirt fan relay
Old Oct 6, 2008 | 08:06 PM
smackhead999's Avatar
logical progression
fan relay
what would make my fan relay buzz and get really hot? wrong connections? i figured you can connect the coil terminals either way and achieve the same thing, and the same with the load terminals. im sure im not the first person to experience this.
Old Oct 8, 2008 | 08:38 AM
Aaron Cake's Avatar
Engine, Not Motor
The coil connections are non polar. As are the contact connections.
How exactly do you have it wired? First though, just try another relay.
Old Oct 8, 2008 | 12:58 PM
logical progression
yeah i guess it could be bad. i used the diode across the signal to ms and the 12v supply. with the line on the diode towards 12v. the 12v for the coil is the same as the contact 12v. i have the relay on the ground side of the fan, inline, with a fuse.
squirrels
Sep 1, 2024 09:52 AM
