what and how often do you perform maitenance on your FD?
Old May 12, 2002 | 11:50 AM
importadrenelin's Avatar
Question what and how often do you perform maitenance on your FD?
Hi,
I just got my FD and I wanna make sure it is maintained RELIGIOUSLY. Anyways I did a search under "General Maintenance" and really didn't get the answers I was looking for. For now I know the following:
1)Change oil every 2000miles & don't use synthetic
2)Always check fluids
3)thats about it
So just wondering what else you guys check on a regualr basis to make sure your car is in great running condition.
please let me know, or if there is a link you can refer me to that would be great, I tried the www.scuid... but it didn't tell me what I was looking for.
Old May 12, 2002 | 12:00 PM
R1Outcast's Avatar
Constantly check coolant and oil levels...at least once a week. I chang the oil every 1500 miles.
Old May 12, 2002 | 12:07 PM
SanJoRX7's Avatar
uid 0
I change the oil every 2500-3000. As long as you're using a quality filter and checking the level and quality of your oil every other drive, you'll probably be ok. Generally speaking, the harder you drive your car, the more often you'll need to change the oil.
Fuel filter is recommended every 15k miles or so. This is critical in maintaining a free flowing fuel system and prevents fuel starvation which can lead to a blown engine.
Check your tire pressure once a week or so, adjust accordingly (remember, tires are porous and lose pressure over time).
Check your brake fluid every 3-4 drives to make sure that the screen is clean and you've got enough.
New plugs every 15-30k isn't a bad idea. Problem is that replacing them is a pain, so don't go crazy here.
Wash the car every couple weeks if not more frequently just to make sure you're keeping it nice and happy
Oh yeah, and inspect your tires every couple weeks to make sure that your tread is still in good shape and that you're not getting screwy wear on them. If you have all the same tires all the way around, rotate them every 5k to help even out the wear.
Old May 12, 2002 | 12:09 PM
Import Convert's Avatar
There is nothing wrong with using synthetic!
Old May 12, 2002 | 12:12 PM
Mahjik's Avatar
Mr. Links
Arrow
Read through this thread as well:
https://www.rx7club.com/forum/showth...threadid=55664
