EGTs, not just for breakfast anymore
Old Sep 21, 2008 | 02:19 PM
Howard Coleman's Avatar
Racing Rotary Since 1983
i have been digitally logging (Power FC/Datalogit) EGTs pre-turbo for a couple of years.
quite easy to fixture and inexpensive. get the FAST acting (instantaneous) thermocouples from TEAMRIP.com, around $50 each and the solid state signal convertor at simple circuitboards.com ($35 ea).
connect to your dataloggit and start logging.
recently i realized that i had been focusing on my egt target at one bar (1550 F preturbo) but had not really considered the transition area from zero to 15 psi.
a look at my logs showed good AFRs in that area but EGTs around 1050!
so i called my go to guy, Jose Le Duc, and found that the number should be 1420!
here's the point.... my AFRs were fine. BUT my egts were, uh, not fine.
so we worked the timing and before we ran into an unrelated problem (inconsistant alcohol pressure) had the egts up to 1350.
lots better spool, torque etc.
this points out that AFRs aren't everything.
get tuning.
howard coleman
Old Sep 21, 2008 | 02:28 PM
tt7hvn's Avatar
awesome advice and well explained
Old Sep 21, 2008 | 04:59 PM
Dudemaaanownsanrx7's Avatar
wannaspeed.com
did u end up increasing the timing overall? is this on the stock twins or a single? and finally are you running dual EGT probes or just one? interesting observation on the EGT's during spool
Old Sep 21, 2008 | 05:00 PM
AHarada's Avatar
So you're shooting for
0"-14psi 1420 and 15psi+ 1550
Is this correct?
Old Sep 21, 2008 | 06:32 PM
yes, we increased the timing.
my setup is two garrett TO4s. total airflow is similar to a GT42 but at 25 psi.
i have an EGT probe in each of the two runners between the engine and turbo.
and yes, 1420 to one bar and 1550 after.
should be back on the dyno this week w my re-jiggered alcohol setup.
hc
Old Sep 21, 2008 | 06:51 PM
RX7 RAGE's Avatar
Bann3d. I got OWNED!!!
Top Answer: 1
How much should we add to the temperature if the bung is 6" or so downstream of the downpipe?
Old Sep 21, 2008 | 07:13 PM
wannaspeed.com
wouldnt you reduce the temp if it was on the downpipe? since its further from the combustion area
Old Sep 21, 2008 | 07:19 PM
Trout2's Avatar
Yes, EGT's post-turbo are lower than pre-turbo. Lower because the turbine absorbs heat that's wasted from the combustion.
Jack
sunburn's Avatar
Mother****ing Wow
nope... the exhaust gets heated up at the turbine.
IMO too many variables... why not move the bung pre-turbo? not really that much work involved.
Old Sep 21, 2008 | 08:47 PM
cewrx7r1's Avatar
Eye In The Sky
Howard,
How did you calibrate the sensors so that the DL will record accurately?
Old Sep 21, 2008 | 08:58 PM
"How much should we add to the temperature if the bung is 6" or so downstream of the downpipe?"
i did a study re pre and post turbo egts (i actually digitally logged both at the same time) and found the relationship is quite variable depending on where you are on the map. there are numerous posts on this board stating you add 200 degrees or whatever. unless you have tested post and preturbo i believe that post turbo egts are of low value. you really want to know the pre turbo number and it DOES matter.
"How did you calibrate the sensors so that the DL will record accurately?"
since the various translator circuits generally use the AD595 i just used the look up table from AD.
hc
Old Sep 21, 2008 | 09:31 PM
dean23's Avatar
pwned
can info like this get stickied? this is EXTREMELY valuable.
Old Sep 22, 2008 | 12:49 AM
moconnor's Avatar
The PLX Devices EGT units are also an alternative transducer choice. Not as cheap as the Simple Circuits units but nicely packaged. cf. http://www.plxdevices.com/products/sm/egt/.
Old Sep 22, 2008 | 10:28 AM
arghx's Avatar
rotorhead
did increased EGT's during spool correlate with actual quicker spool times, or more area under the power curve? Did you have a quantifiable improvement in performance?
Old Sep 22, 2008 | 11:07 AM
yes, yes and yes.
back on the dyno this week.
Old Sep 22, 2008 | 11:09 AM
Mahjik's Avatar
Mr. Links
If someone is running the stock twins manifold, it may not be an option.
Old Nov 27, 2008 | 11:53 AM
arghx's Avatar
rotorhead
any updates on EGT's we should target and their effect on the boost and power curve?
Old Nov 27, 2008 | 07:43 PM
Monkman33's Avatar
Goodfalla Engine Complete
https://www.rx7club.com/attachment.p...6&d=1169056439
Actually... It Is an option.
Old Nov 27, 2008 | 08:18 PM
fd_neal's Avatar
what is the ideal distance from the motor for the probes? I would imagine a few inches would make a difference.
Old Nov 27, 2008 | 09:00 PM
RLaoFD's Avatar
Brappable not Unflappable
Originally Posted by Monkman33
not everyone (me) has the resources to do something like that. It's much simpler if one can be placed in a certain position in the exhaust and we have a temperature to aim for from there.
Old Nov 27, 2008 | 10:01 PM
Nateness's Avatar
Spooling
LOL sorry man, but where is the heat coming from? Sounds like a violation of one of the thermodynamics laws to me. The exhaust gases heat up to their highest temperature at combustion, then they will shed heat from that point forward. The turbine heats by receiving energy from the gases, not the other way around.
The exhaust gasses will definitely become cooler as they travel downstream. As the gas moves through the exhaust components, it will shed heat primarily through convection to the exhaust side walls. The exhaust sidewalls will in turn shed heat through the three main modes of heat transfer: conduction, convection, and radiation.
So to answer some peoples' question, there is no generic "rule of thumb" offset that you can apply to thermocouples that are post turbine. Different exhaust materials, ambient temperature conditions, etc. will change this value on a case by case basis.
Old Nov 28, 2008 | 12:53 AM
wannaspeed.com
Thats what i was thinking as well. The only thing i could figure is if it was actually combusting in the turbo maybe it could be hotter. But thats not really a typical system unless we're refering to a rally car with anti lag.
Old Nov 28, 2008 | 09:25 PM
Monkman33's Avatar
It is worth it in my opinion, to pay a machine shop $75 bucks to get it done.
Then you can get readings from front and rear rotor separately. The front and rear tend to have balance issues.... especially if you are running a stock LIM.
Old Nov 28, 2008 | 10:30 PM
RX72NR's Avatar
paying to play
Howard, do you have any pics of your turbo manifold?
Old Nov 29, 2008 | 05:13 AM
neit_jnf's Avatar
id like to see the complete turbo system!
