Best deal on underdrive pullies?
Old May 11, 2002 | 02:12 PM
NOTA V6's Avatar
I was just thinking that we could save my fingers from doing the walking.
Anyone have a tip on where the best price on a good set of underdrive pullies might be? Ones that come in colors would be cool, but any of them can be painted I guess.
The motor they are for is a '90 J-spec turbo...
Thanks,
Old May 11, 2002 | 05:56 PM
NZConvertible's Avatar
I'm a boost creep...
I'll try to save you some money instead. Underdrive pulleys are a waste on a road car. Your alternator is gutless enough without you slowing it down and lowering its output further. You should only underdrive your water pump if cavitation is a problem, which it is not on a street car. Unless you spend a lot of time at constant high rpm (i.e. race car), you will not notice any difference (you'll be lucky to see 1-2hp on a dyno), but you may cause cooling and charging problems.
Old May 12, 2002 | 09:53 AM
NOTA V6's Avatar
Thanks for saving me the money. Dual belt pullies it is...
Smokeyfb33
Old School and Other Rotary
Oct 1, 2015 12:10 PM
