think i may have a series of problems, please help :(
Old Sep 16, 2008 | 07:27 PM
v6mike's Avatar
Essex Boys
Question think i may have a series of problems, please help :(
i have a 93 fd3s r1
i have a series of running problems, which any help would be much appreciated
first of all when the car is all warmed up, the boost is inconsistant showing only about 6psi until 5500rpm in second gear then it boosts up to 10psi & goes like ****!! this doesnt happen in any other gear (just stays at 6psi)
second of all is when the engine is really hot (so the fans are kicking in) she idles very inconsistant by dropping very low (about 450rpm) back up to about 800rpm, and takes a few seconds to settle herself to 700rpm (sometimes she doesnt)
also when the engine is this hot, the acceleration is very jerky and power delivery is very on-off - almost impossible to drive
please help
i have changed the fuel filter
plugs
tps sensor
airfilters
& checked all my hoses
(could it have anything to do with my secondry throttle?)
(or any of my actuators)
im running out of ideas
its so frustating
Old Oct 9, 2008 | 09:39 PM
doomsday993's Avatar
check all the grounds and all the vaccum lines
Old Oct 10, 2008 | 01:46 PM
v6mike's Avatar
Essex Boys
thanks im going to add more grounds to the car
Old Dec 16, 2008 | 11:18 AM
v6mike's Avatar
Essex Boys
problems cured :)
the boost problem was the PCV valve, in which i just bypassed like the later models do
then the running & idle problems were all down to the IAT sensor & i found this out by pluggin an APEXI PFC into it, in the end i bought the PFC for a bargain price of £250 & got her rolling roaded
she now runs like a dream
ZacMan
Sep 19, 2015 09:20 PM
ncds_fc
19
Sep 15, 2015 12:03 AM
sinistersam
Sep 13, 2015 07:17 PM
