What the hell is a carb jet?
Old May 10, 2002 | 03:16 PM
ejmack1's Avatar
Lawn Ornament
Sorry for my ignorance but i have no clue!
Old May 10, 2002 | 03:41 PM
turbojeff's Avatar
Do it right, do it once
Re: What the hell is a carb jet?
It is a small piece of metal, maybe .25" in diameter that is threaded on the outside and has a hole on the inside. Changing a carb jet is sorta like changing the pulsewidth on the injectors, it changes the amount of fuel the engine gets.
For this forum's purposes we use them as "pills" to tweak the boost since you can buy them in many sizes and they fit tightly in a hose.
Jeff
Old May 10, 2002 | 04:14 PM
cewrx7r1's Avatar
Eye In The Sky
I did a GOOGLE search and found explanations of the question on the first page of sites.
Old May 10, 2002 | 04:55 PM
ejmack1's Avatar
Lawn Ornament
shut up im at work and didn't feel like searching.. there i said it.. I DIDN"T FEEL LIKE SEARCHING ... ok i guess i could search to see where i can purchase them at, but im just going to ask it here!! This will work with a manula boost controller, right? Between the WG solenoid and WG actuator?
Old May 10, 2002 | 05:30 PM
it works like a boost controller. when you get a chance, search for carb jets or boost pills.
Old May 10, 2002 | 07:28 PM
ejmack1's Avatar
Lawn Ornament
I currently have a Dawes Device hooked between the Y pipe and WG actuator, but i still have the hose going from the WG to the solenoid. What im trying to figure out is, do i put a carb jet on the other side of the WG and disconnect it from the solenoid?
BTW: Thanks for the responses
Old May 10, 2002 | 07:47 PM
happyham's Avatar
u put a carburetor jet on a wastegate? what happens when you do that?
dona1326cosprings7
Oct 29, 2015 06:47 AM
NLPerformance
Oct 2, 2015 07:11 AM
