Can you identify these??
Old Sep 8, 2008 | 03:39 PM
DrifterDuo's Avatar
Exclamation Can you identify these??
I scoured my haynes manual and came up with nothing, I'm hoping someone will make quick work of this.
on the vac diagram, it shows only one line coming out of here, not three
I'm hoping I didn't lose whatever it was I took off here, and I thought I was good about setting the little things aside
I think my vac lines were screwed up before I even touched them and the haynes has been a big help so far, but these two things were a bit too tricky for me, thanks for any feedback I get.
Edit: If any more pics are needed, let me know
Old Sep 8, 2008 | 03:51 PM
classicauto's Avatar
Crash Auto?Fix Auto.
Top pic is the Cold start assist piece. Its supposed to inject some crap in the engien for helping it start when its really cold out. You can chuck it, chances are it doesn't work (Mazda had a TSB about removal actually...) But hey, if it floats you boat keep it there, I'm unsure whether having the vac nipple open on it will cause a vac leak or not however....
The bottom pic is for the EGR, should have a tube running to the cat.
Old Sep 8, 2008 | 04:15 PM
DrifterDuo's Avatar
top pic- i unbolted that cold start assist long ago haha, I'll cap them off to be safe.
bottom pic- split air pipe, awesome
Old Nov 3, 2008 | 07:22 PM
texFCturboII's Avatar
version 2.0
What about the similar looking hole below the split air pipe? Ssomething is attached in the pic, I've got nothing there though..... another block off plate then, yea?
Old Nov 3, 2008 | 08:45 PM
DiabolicRX7's Avatar
cant be a blockoff plate, its got a pipe/tube coming off the center of it and runs to something....
Old Nov 3, 2008 | 08:49 PM
87 t-66's Avatar
not a drifter
the split air pipe comes off there and provides fresh air to the cat. if you have a stock exhaust i would recommend putting it back on.
Old Nov 3, 2008 | 11:37 PM
version 2.0
weeeeelllll, i just bought a block off plate for it....
no stock exhaust.
Old Nov 4, 2008 | 06:45 AM
mazdaverx713b's Avatar
Have RX-7, will restore
no, but do you have a catylitic conveter?
Old Nov 4, 2008 | 12:19 PM
DrifterDuo's Avatar
that similar hole is for the turbo oil line
Old Nov 4, 2008 | 12:34 PM
87 t-66's Avatar
not a drifter
Old Nov 4, 2008 | 12:36 PM
87 t-66's Avatar
not a drifter
Originally Posted by DrifterDuo
that similar hole is for the turbo coolant line
fixed.
Old Nov 4, 2008 | 12:46 PM
DrifterDuo's Avatar
ah, i thought it was an oil line, i forgot that was a water jacket
Old Nov 4, 2008 | 04:55 PM
version 2.0
ahhhh ha, yea i forgot i re-route that... thnaks for the clarification.
vqturbo
Old School and Other Rotary
32
Aug 11, 2023 07:29 PM
pzr2
Sep 8, 2015 10:46 AM
Frox
Sep 8, 2015 08:36 AM
ppritchard
Interior / Exterior / Audio
Sep 2, 2015 07:44 PM
