Ola, new member here.
I'm a new registered member however I've been reading threads for years.
Owner of numerous rx-7s but am currently without a single rotary. Well, that's not true, I've got engine pieces but nothing to put it in. I'd like to find a '79 /'80 if anyone knows of one in central U.S. Also interested in building my own Norton if anyone can offer assistance.
Thanks,
Glad to be here.
Thanks,
Glad to be here.
Kinda hard to explain where enid is, there's only one in oklahoma, so I'd just google map it. It does run, but it needs work, so defiantely tow. The carb is outta whack, seats need to be recovered, stick car, pop up sunroof, trans is good, brakes are good, tight suspension. When I ran it last, it didn't smoke, but the front main seal has a small leak. Driver's fender is dented by the door, and would need either work on it or replacement. It has a small rust hole on the driver's side rear quarterpanel behind the wheel, everything else looks good. It's a project vehicle, it has alot of good parts, and can either be finished out or be a great source for another car. I've got about $500 in parts for it that go with it.
