Replace O2 sensor
Old May 9, 2002 | 11:16 AM
Question Replace O2 sensor
How often should O2 sensor be replace? Local auto parts store indicates replacing O2 sensor every 50M miles.
Old May 9, 2002 | 11:27 AM
50m Miles?
Old May 9, 2002 | 11:33 AM
RETed's Avatar
50 million miles - wow, that's some industrial grade O2 sensor!
Seriously, about every other year or 50k miles is about right.&nbsp It's cheap when you start using generic O2 sensors with pigtail bare wires with a crimped connector.&nbsp It's cheaper than swapping spark plugs!
-Ted
Old May 9, 2002 | 11:42 AM
If you don't replace O2 sensor every 50K miles, will gas mileage and performance suffer? If self-diagnosis checker (code 5) does not indicate problem with O2 sensor, replacement is unnecessary?
Old May 9, 2002 | 11:47 AM
RETed's Avatar
Too many variables...
If you keep the O2 sensor "clean", they can last over 100k miles.&nbsp The problem with O2 sensors nowadays is that most modern gasolines have additives that leave all kinds of nasty deposits on them - all that orange and pink crud on your old O2 sensor is deposits from gasoline additives.
When O2 sensor performance degrades, they become lazier to react.&nbsp This can hurt mileage in the long run.
-Ted
streetlegal?
Mar 17, 2022 02:46 PM
