help me!!
Old Aug 26, 2008 | 06:37 PM
r-x-7's Avatar
Newbie
help me!!
ok, Im planning to buy a first or second gen. rx7.
Im wondering.. whats the difference, as far as engine and suspension!
do they both have independent suspension?
Old Aug 26, 2008 | 08:22 PM
Icemark's Avatar
first gens do not have independent rear suspension, but have independent front suspensions.
2nd and 3rd gens have fully independent front and rear suspensions
Old Aug 26, 2008 | 10:42 PM
SLOASFK's Avatar
Top's always down
Everything he said, plus...
First gens came with a 101hp 12A or a 138hp 13B option added in 1984. They were very light, around the same weight as an early Miata.
Second gens came with a number of different power options depending on year. 86s came with a 145hp N/A 13B motor. 87-88s were available in several different options packages with the 145hp N/A motor, and one package which had a 180hp Turbo 13B. 89-91s came again in several options packages of 160hp N/A 13B motors and one 200hp turbo 13B motor package.
Obviously the 89-91s, are harder to find and the most expensive of the early RX-7s. Generally 79-88s all cost around the same, except for the turbo models which are a little more expensive.
As Mark said, the first gens came with a solid 4 link rear axel and an independant front suspension. Whereas the second and third gens came with 4 wheel independant suspensions. Some of the second gen models came with electronically controlled suspension stiffness, basically stiff and rattle your teeth out. They also came with a passive 4 wheels steering system called DTSS. This can come as a shock to new RX-7 owners who aren't expecting the rear to suddenly lock inline with the front wheels when cornering hard.
Old Aug 27, 2008 | 01:59 PM
r-x-7's Avatar
Newbie
thanks!! I am going to buy a 87 or 88!
im looking now
i hope a turbo!!
Old Aug 31, 2008 | 02:56 AM
Vince.SUE's Avatar
Anyway you can buy a 1st gen a buy pieces of a 2nd gen to change it in your car, I think it's possible (lot of people change their Evo 8 turbo with a Evo 9 turbo...I know it's not same thing but just to say that it's possible to change pieces between 2 models :-)
Old Sep 1, 2008 | 05:49 PM
farberio's Avatar
NASA-MW ST4
^ This is not really true of first and second gen RX7's. The interior is completely different. The FC Rear end will not bolt into the SA/FB without extensive modification. I am not sure about the front suspension. The SA/FB non GSL-SE uses the 12A and is not easy to mount a 13B in there without extensive modification.
However, the 13BGSL-SE has the engine mounts in the front cover making any 13B engine easily mountable.
Old Sep 1, 2008 | 06:51 PM
Ryan123's Avatar
The Slowskys
Some people pick up an 83 and Put a turboII in it.
Old Sep 2, 2008 | 10:28 PM
kyjaxskater's Avatar
so, why would you pic a 1st over a 3rd gen, besides personal preference?
Old Sep 3, 2008 | 12:55 AM
Tigerx7's Avatar
AAAAAAAAYYYYYY!!!
my guess would be price tag. A first gen can be had for less than 2K dollars, whereas a third gen in decent condition will cost you 7-8K, and that's if you're lucky.
Old Sep 3, 2008 | 01:28 AM
AreExSevenProject's Avatar
drift city
make sure to go to aaroncakes website and find a check list for your car. Most private sellers do not know rotarys. Make sure it runs cherry before you even think about buying it. I bought mine just because it had a good engine and now im getting 6 grand offers for it lol
