Shifting Question For you guys??
Old May 8, 2002 | 09:47 PM
Question Shifting Question For you guys??
When im racing someone or just messing around at about 7000rpms it feels like my car has no more pulling power or anything do you guys let your car redline before you shift i mean i would usually do that but im not getting anymore pull out of my car after that any answers to this from anyone!!
Old May 8, 2002 | 09:56 PM
BhamBill's Avatar
Redline is past the HP/Torque peak for all stock cars. Redline is set as the maximum safe RPM for the engine. You should shift at or just past the power peak.
Rattaan's Avatar
we...yota...
I used to have the same problem, but at the suggestion of mazdaspeed7 ??? I think? I took apart the intake manifold and port matched it. I ground down the chunk in the plastic elbow in front of the throttle body, and cleaned the throttle really well too. Now it pulls through 7k on up to 8k with only a slight drop(barely noticeable) at around 7k. Even in third gear I rev to 8k (100mph at this point ) Definitely worth the effort, as it smoothed the acceleration a bit too.
Old May 8, 2002 | 10:07 PM
autocrash's Avatar
Now with more 1st Gen!
question: when you guys are just cruising, what RPM do you shift at and what RPM do you cruise at?
As well, where, approximately, is the power peak on an '89 N/A?
Old May 8, 2002 | 10:09 PM
what do you mean by port matched it anything special i need to do this?
Old May 8, 2002 | 10:13 PM
whats the peak rpm's/torque on a 90GXL any clue anyone
Old May 8, 2002 | 10:23 PM
mazdaspeed7's Avatar
mad scientist
Click the pic in my sig, I have pics and a how-to for porting an intake manifold.
Old May 8, 2002 | 10:24 PM
nitroracer's Avatar
Dub'N
for just normal driving i shift at 3 ...when i race i lanch at 3 and power shift at 7
Old May 8, 2002 | 10:34 PM
autocrash's Avatar
nitroracer: thxs man... just starting to get used to this whole manual transmission thing.... (atleast I was, til it blew up... )
Old May 8, 2002 | 10:36 PM
powershift?
Old May 8, 2002 | 10:42 PM
nitroracer's Avatar
Dub'N
ya powershift is when u keep the gas down onthe floor when u shift
Old May 8, 2002 | 10:46 PM
kleach18's Avatar
Just Looking Around
And F*** up your trans!!!!!!!!!!!!
Old May 8, 2002 | 11:14 PM
nitroracer's Avatar
Dub'N
no not really if u know how to do it...
Old May 8, 2002 | 11:26 PM
mad scientist
Old May 8, 2002 | 11:40 PM
TheBigOne's Avatar
Power shift
its ok to power shift as long as you do it right. match the speed of your synchro-gear to the speed of the out put shaft and you can power shift all day without damage.
Old May 8, 2002 | 11:44 PM
nitroracer's Avatar
Dub'N
^i agree with thebigone^
Old May 9, 2002 | 12:58 AM
UniqueTII's Avatar
Slow and old
I launch my TII at 6000 and shift at 7200...but I shift kindly, especially into second. That's probably what's keeping me out of the 13s, but it keeps my tranny alive.
Old May 9, 2002 | 09:14 AM
HuggyBear's Avatar
the best shift is a sure shift...... i dont force it or power it......
id rather do it right every single time
Old May 9, 2002 | 10:12 AM
turbotwista's Avatar
I launch at 4K and shift a 6600 and I am turning 13.4's in the 1/4 I shift kindly because I know how much of a pain it is to take out and install a tranny. this in in my TII
Old May 9, 2002 | 10:22 AM
RETed's Avatar
Re: Power shift
I'd like to hear how this is possible?
There is no such thing as doing it "right" - when upshifting, the rev match to previous gear is always going to be lower on the RPM scale.&nbsp Explain to me how do you rev-match the engine with the transmission if you don't lift on the gas pedal???&nbsp Last time I checked, leaving your foot on the gas pedal and popping the clutch will cause the engine revs to INCREASE, not decrease.&nbsp So explain to me how having the engine revs always INCREASING in this sitaution be able to rev match for the upshift if you need to DECREASE the revs.
Please people, "power shifting" is hard on the transmission and the synchros.&nbsp It's an idiotic thing to do to a modern synchromesh transmission just to win a race.&nbsp This causes unnecessary wear and tear on your drivetrain just because you want to win a race.&nbsp Don't be complaining you blew up your transmission messing around with power shifting.&nbsp If you happen to misshift trying to do this, you're going to almost guarantee kill the synchro in the next gear or even take out the gear itself.
If you wanna be like TheBigOne and nitroracer and take the chance on ruining your transmission, go right ahead; I can only give you my opinion on why this is not recommended.&nbsp Just be aware of the consequences - remembers, there is nothing free about performance and going faster.
-Ted
Old May 9, 2002 | 06:16 PM
autocrash's Avatar
Full-out agreeance with RETed... Better to learn how to shift PROPERLY.... and get good at that... than to kill ur tranny...
Old May 9, 2002 | 06:43 PM
BhamBill's Avatar
Re: Re: Power shift
Oh yes, but at least with a rotary you don't have to worry about the valves floating from the over-rev killing the engine too!! Ah, the days of my youth.
Old May 9, 2002 | 08:06 PM
nitroracer's Avatar
Dub'N
when i power shift i revout to 7 then push in the clutch and let it go to 8 then so why do u think u are gunna riun ur tranny someone please explain...i was think it was bad for my tranny cuz i dont let it go passed 8500...
Old May 9, 2002 | 08:25 PM
autocrash's Avatar
The point is that its really hard on the syncros when you do this.... so don't...
Old May 9, 2002 | 09:08 PM
Not only that, you'll burn up your clutch in no time.
