Gadget feature: Measure your Rx-7's performance with an iPhone
Found this news interesting for iPhone owners:
_________
The iPhone gets yet another use: measuring car performance
By Justin Berka | Published: August 18, 2008 - 09:17AM CT
Sure, you can limit you iPhone 3G usage to phone calls, SMS, a map or two, and the occasional photograph, but if you're feeling adventurous, your iPhone can become quite a bit more. And, as sound level measurement app SoundMeter proves, the sensors inside the iPhone 3G are actually quite good; they can be used for quite a few things you may not have thought possible. MacNN recently pointed out one such application, Dynolicious, which uses the iPhone's accelerometer to record vehicle performance data.
That's right, you can now see just what kind of performance numbers your car is putting up, even if you're just driving around town and want to see what part of the 0-60 of your Camry is at. By frequently measuring accelerometer data, Dynolicious can calculate the time it takes for you to reach any speed between 10 and 100 MPH. It can also give elapsed times and trap speeds (the speed of the car at the end) for a variety of distances, including the quarter and eighth miles.
If you have the urge to drive on a skidpad in order to measure g-forces, Dynolicious can handle those measurements too, and will provide lateral and braking forces. Last but not least, adding vehicle weight data to the app will allow it to estimate your wheel and engine horsepower. All of the data is displayed and graphed in real-time, and can be saved for later review.
As with SoundMeter, the Dynolicious readings are said to be pretty accurate once you have calibrated it, but the company s also planning to compare the app with dragstrip timing software. Another similarity between the two applications is that both have low prices.
______
Here's the link: http://arstechnica.com/journals/appl...ar-performance
_________
______
It measures g-forces under acceleration, coupled with the weight of your car, it'll give you an approximate number.
It was actually pretty close on my friends phone compared to the actual dyno of his car.
The1Sun
Sep 15, 2015 04:45 PM
rx8volks
Canadian Forum
Sep 1, 2015 10:46 PM
