can I remove my ACV on my 88TII??
Old May 8, 2002 | 02:19 PM
BlackRx7's Avatar
Daily Domestic Killer
simple question
Old May 8, 2002 | 04:59 PM
LLADNAR's Avatar
sure i did on mine
Old May 8, 2002 | 05:43 PM
NZConvertible's Avatar
I'm a boost creep...
If emissions checks aren't a concern, go for it. Take out the air pump and cat too, as the pump's useless without the ACV, and the cat will clog and die quickly without the air injection.
Old May 8, 2002 | 05:48 PM
BlackRx7's Avatar
What about the pressure sensor, and all the other connectors, my air pump and main cat are gone. MY question now is what all do I have to do if I remove the AVC, EGR?, BAC? next question whats the best material to make a block off plate out of? will aluminum suffice?
Old May 8, 2002 | 07:19 PM
Tee the pressure sensor line into the BOV line. Make sure the pill is still in the pressure sensor line.
Just answered this here. EGR's the same; just remove, block hole with plate, cap vac line.
Ali's fine, ~3mm thick
Old May 8, 2002 | 09:30 PM
BlackRx7's Avatar
Thanks NZ YOU rule
Bauer778
Nov 4, 2015 04:42 PM
Steelwheelz
Sep 15, 2015 03:22 PM
