Rtek Forum Discuss the Rtek 2.0 and other Rtek ECU's
Rtek Glitches with my RTek stage 2?
Old Aug 16, 2008 | 01:59 PM
theory's Avatar
Rotary Dynamics
I went to set my idle with the RTek today and this is what happened:
Checked off initial set coupler.
It said it had to above above 164 degrees but it said the car wasn't warmed up yet and woudln't give me my actual temperature.
I went back to my logging screen where the car was reading 183 degrees.
I click next anyways seeing as the car was actually warmed up fully, and at the TPS stage, it said I must adjust to make it 20%, but it wouldn't give me what my reading was, it just said it wasn't within range...
Sometimes when I want to log, I change the parameters I want to log, but when I go to the log screen, the parameters didn't change and it's just back to an old setting?
Anyone else have this problem?
Old Aug 17, 2008 | 08:41 AM
HAILERS's Avatar
HAILERS
Yeah. I've seen where the screen said it was not up to temperature and that was bullshit. Because I'd already had the engine running for sometime and ALSO looked at the water temp which was in the 185 degree range. So, that puzzled me also.
I more or less backed out of that feature of setting idle and went and looked at water temp again and some other things and THEN returned to the SET IDLE screen. If memory serves it took two times of this backing out procedure to get it to function right and show the real water temp and let me go on to set the idle speed.
Short answer is YES, I've seen it and overcome it by *turning the thing off and back on* so to speak. Sorry, never let DIGITAL TUNING know about it because I *overcame* the problem. Lazy be I.
That was stage 2.1.
Old Aug 21, 2008 | 07:05 PM
HAILERS's Avatar
HAILERS
I've had this problem on the non turbo car also. The best way to overcome it was to get out of RTEK on the Palm and enter another progarmm like Zeitronix or whatever else you have, then going back to the RTEK programm.
Old Aug 21, 2008 | 08:30 PM
theory's Avatar
Rotary Dynamics
I will give that a try first chance I get. So far nothing else has worked. I'm also in the process of creating a help ticket at pocketlogger.
Old Aug 22, 2008 | 04:57 PM
HAILERS's Avatar
HAILERS
Thanks for doing the HELP ticket. That's the only way it'll get fixed.
Old Aug 26, 2008 | 09:02 PM
theory's Avatar
Rotary Dynamics
Apparantly I had the old version of the software. The latest software was provided very promtply might I add.
I will try that and see what happens.
WyomingTII
Rtek Forum
Oct 26, 2015 05:26 PM
LongDuck
Oct 7, 2015 08:12 PM
lnlreaper
Sep 27, 2015 09:59 AM
