Removing water spots from paint?
Old Aug 8, 2008 | 03:02 PM
staticguitar313's Avatar
R.I.P. Icemark
Anyone have any tips? Last owner must have had this car parked next to sprinklers for years . . .
Old Aug 8, 2008 | 04:55 PM
Uncle Hungry's Avatar
Talk to me....
Rubbing compound, if it's bad enough you may need to wet sand and worse case scenario is you just can't get it out at all without a repaint. ( probably the case )
Old Aug 8, 2008 | 05:38 PM
classicauto's Avatar
Crash Auto?Fix Auto.
A water spot would be a ring of dust left on the paint after a bead of water has dried. That can be wiped with rag, rubbed with microfiber cloth and rubbing compound.......rewashed and chamois'd..............whatever.
If its not a water spot (damage on the paint) thats another story
Old Aug 14, 2008 | 10:05 PM
NCross's Avatar
I have a rotary addiction
If its covering a good amount car go down to NAPA and buy a bottle of 3M liquid rubbing compound for about $14. Fantastic product! Works great for getting wet sand swirls out of new/old paint and shines it enough to look great. I would recommend you buy a good quality cleaner wax too such as Zymol. Don't cheap out and buy cheap wax products. It is worth the money.
Old Aug 14, 2008 | 10:06 PM
NCross's Avatar
Although it could be chemicals that ate away at the paint... Carb cleaner, brake cleaner, brake/clutch fluid.
Th0m4s
Feb 26, 2019 02:04 AM
incubuseva
14
Sep 3, 2015 12:37 PM
mazdaverx713b
19
Aug 29, 2015 12:30 PM
Frisky Arab
13
Aug 18, 2015 05:30 PM
