Transmission Mount
Old May 6, 2002 | 11:44 PM
rx-7fc's Avatar
Transmission Mount
how much is a Transmission Mount from mazda motorsports and it is for a na and i want the better one
Old May 7, 2002 | 12:12 AM
Scott 89t2's Avatar
SOLD THE RX-7!
$10 each. need 2
Old May 7, 2002 | 10:19 PM
rx-7fc's Avatar
ok thanks do you know the part #or do i just call them
Old May 8, 2002 | 02:09 AM
RETed's Avatar
http://fc3s-pro.com/TECH/MODS/TRANS/tmount.htm
This should be the same for all 5-speeds, turbos or not...
-Ted
Old May 8, 2002 | 05:07 AM
Liquid Anarchy's Avatar
We come with the Hardcore
I'll piggyback this thread
Ted, would you suggest changing the trans mounts while I have the engine out? I'm ordering the Mazda Motorsports engine mounts, and I've toyed with the idea of getting the Trans mounts too and doing it all at once.. is it worth it? or is it easy enought just to jack up the tranny if the OEM's ever give out?
Old May 8, 2002 | 05:39 AM
RETed's Avatar
I don't usually mess with the crossmember.&nbsp That rubber bushing in there is weak!&nbsp I usually just tighten the bolt down so it doesn't move around - I think flipping the bottom "washer" helps get the spacing right.
-Ted
