Megasquirt Needed: .MSQ file
Old Jul 30, 2008 | 12:48 AM
SpecFC's Avatar
SOUL-LESS
Needed: .MSQ file
I am in desperate need of a base tune to get my car run to try and diagnose some problems, id like to remove the tune as a factor.
Does anyone have a good tune for a stock port, turbo motor, with 720cc primaries?
Any help greatly appreciated.
Old Jul 30, 2008 | 07:44 AM
toplessFC3Sman's Avatar
you could prob use any of the turbo maps that people have uploaded, and just change the req_fuel value in basic constants to reflect your primary size as well as the staging factor in advanced settings to tell the MS how big your secondary injectors are. Also watch for the spark settings, some people are running stock CAS's, some have cut two teeth out.
I know i've posted mine up here within the past week or so, but regardless of who's msq you go with, make sure you have some way of monitoring AFR (wideband is preferable, narrowband I would only use when not boosting). Do a bit of reading to make sure that all the settings are applicable to your car, and that the configurable outputs are connected the same way for you.
joel(PA)
Oct 4, 2015 06:07 PM
