Got a Hesitation problem what should i do??
Old May 6, 2002 | 11:02 PM
Type RZ's Avatar
I get a hesitation whenever i hit boost. im not sure what might be the problem i think its my fuel filter and pump going bad. I think that there isnt enough fuel going into the motor. but im not sure..... so if someone could help me out that has maybe had this same situation happen to them or something simillar.
Thanks
Rob
Old May 6, 2002 | 11:49 PM
user 84205's Avatar
lots.... could be wrong..... more info
Check turbos....
Old May 7, 2002 | 12:03 AM
cafe's Avatar
If it's happen around 3000 RPM then you have to live with it.
Old May 7, 2002 | 12:09 AM
GsrSol's Avatar
Z06 powered FD
I would recommend 2 extra ground straps and go from there. You can also reset the ecu and it will probably go away for a little while.
rgordon1979
40
Mar 15, 2022 12:04 PM
Bauer778
Nov 4, 2015 04:42 PM
Feffman
SE RX-7 Forum
Oct 7, 2015 06:57 AM
The1Sun
Sep 18, 2015 07:13 PM
