Power FC Power FC Hot idle and O2 sensor question
Old Jul 29, 2008 | 02:42 PM
Zexxon's Avatar
Money Pit
Unhappy Power FC Hot idle and O2 sensor question
I have learned idle properly according to Dale's instructions.
The car idles perfectly when started for the first time, 2nd and 3rd etc.
However when the car is left out in the sun (100+ F) for more than 30 minutes and is started the idle is incredible rough for about 30 seconds. The water temp is generally 105c at this point and quickly cools down to around 95 or so. Once water temp has cooled it's OK. It seems like the car is almost running too lean due to the temperature? The o2 sensor doesn't give me anything useful in terms of feedback as it doesn't start sending anything back until around 2-3 mnutes of actual driving/idling.
It's not a big deal but it's a tad annoying and in some cases the car will actually stall when attempting to start when it's been baking in the sun.
Any suggestions? Other than that the PFC runs very well if a tad on the rich side.
I have also hooked up my O2 sensor output to the apexi turbo timer and it works well. I suspect though I need a new O2 sensor based on the following:
It takes around 2-3 minutes before the O2 sensor starts generating real readings (i.e. > 0.01 that fluctuates based on accelerator position and rpm level).
The O2 sensor has around 55k miles on it.
Thanks!
Old Jul 29, 2008 | 03:05 PM
arghx's Avatar
rotorhead
this is a common problem and has to do with heatsoak on the intake air temp sensor. you can't mess with it without a datalogit
Old Jul 29, 2008 | 03:38 PM
Zexxon's Avatar
Money Pit
Thanks arghx
That makes sense, the air temp is generally around 85 degrees when I start the car and then it cools down quickly. I am running a stock SMIC which I will be replacing end of this week - that should help with the heat soak.
I am having the car tuned next week and I'll definitely ask about that.
Old Jul 29, 2008 | 07:30 PM
cewrx7r1's Avatar
Eye In The Sky
High heat soak also retards timing as a protection against on-boost overheating.
Old Jul 31, 2008 | 05:36 PM
Dudemaaanownsanrx7's Avatar
wannaspeed.com
replacing the intercooler wont help much with heatsoak of the intake sensor, as it sits right above the engine on a large chunk of aluminum (UIM). The only way to help this is to move the intake sensor but as mentioned you will need the datalogit so you can change the AIT tables.
Old Jul 31, 2008 | 07:25 PM
cewrx7r1's Avatar
Eye In The Sky
Contact BDC as he could make the mod change for you.
http://bdc.cyberosity.com/main.php
smikels
Rtek Forum
May 12, 2016 12:34 AM
alphawolff
Nov 17, 2015 05:57 PM
befarrer
Microtech
Aug 22, 2015 05:52 PM
