what does it mean when.......
Old May 6, 2002 | 10:40 AM
sportykev's Avatar
the car blows white smoke for a couple of minutes when the car just starts up?
Old May 6, 2002 | 10:51 AM
Street King's Avatar
*** Bless Texas!
Thats normal. If it still happens after a couple of minutes then it looks like a rebuild in the future.
Old May 6, 2002 | 11:35 AM
SanJoRX7's Avatar
uid 0
Yeh, if the smoke keeps happening after more than like 2 minutes, you're looking at some bad seals, which means coolant is getting into your engine. The implications there are obvious, so keep an eye on your watch, and maybe start saving money
Old May 6, 2002 | 11:49 AM
rynberg's Avatar
There are a number of symptoms of coolant seal failure:
*white smoke on start-up (not vapor, smoke), the smoke will smell like coolant
*oil in coolant
*coolant level is constantly dropping
*hard starting
*bubbles in coolant on warm-up (check by opening filler cap - not AST - right after start-up, look for lots of small bubbles rising to the surface
Note that most people drive a long time with failing coolant seals. Unlike a broken apex seal, there is almost no danger in continuing to drive it as the damage has already been done.
Good luck.
