Lowering An RX-7
Old Jul 19, 2008 | 06:04 PM
MX3's Avatar
MX3
Lowering An RX-7
I would like to know what is the best equipment or method to lower an FD.
At the same time I want it to look as stock as possible.
Thank You for your replies.
Old Jul 19, 2008 | 06:33 PM
Mahjik's Avatar
Mr. Links
Go with Koni Shocks and RSR Down Springs. There is also the new Tokico HTS Shock/Spring combo.
Old Jul 20, 2008 | 12:26 AM
Rookie84's Avatar
Mahjik, have you tried the Koni/RSR combo yourself? If so, what are your thoughts about it? Which perch did you set them at? I recently picked up a set of Koni's so I'm looking for a set of springs to go with them.
Old Jul 20, 2008 | 08:38 AM
Mahjik's Avatar
Mr. Links
No, I have not tried that combo myself. If that combo (and my wallet) was available when I did my setup years ago, that's what I would have done. What do you use your car for? If you ever do any AutoX or road course, I would recommend just getting some Ground Control Coilover sleeves to go with your Koni's. If you only drive on the street, the RSR Down Springs will give the car a nice stance.
ZaqAtaq
Sep 5, 2015 08:57 PM
