what to do next
Old May 5, 2002 | 09:24 PM
ttb's Avatar
ttb
No Cup Holder Racing
what to do next
hi, i bought a 94 w/ 99k original motor last week. so far i've
*replaced the fuel pulsation damper and fuel hoses due to leaks
* replaced both primary injectors due to leaks
* partial replacement and tie-offs of vacuum line/hose
*replaced lower intake manifold gasket
my mechanic also noticed the following:
* radiator still original, tank may split
* engine leaks oil from stationary gear oring and oil pan
* air pump is still original
* main muffler rusted from inside
* trans make more bearing noise than normal
* engine water seals may fail
* precat partially restricted
* all coolant hoses are original
* turbos housing have good size cracks
he recommended not doing anything engine related since i'll have to get a new one soon. the alignment is also off.
any comments? what should i do next?
thanks
Old May 6, 2002 | 12:04 AM
93TTRX7's Avatar
work more hours and spend less money...downpipe wouldn't hurt though
