help with s5 t2 tans
Old Jul 15, 2008 | 02:58 AM
surfthenskate808's Avatar
uhh im not sure whats wrong with my tranny. this is what happen to my fc...i pulled it out of 1st gear with out pushing in the clutch... now when i did that its stuck in reverse and cant catch any of the gears but 1st and 2nd... but even in 1st and 2nd the reverse light is on...uhh if you need more detal let me know..
thanks
Old Jul 15, 2008 | 03:40 AM
Eple's Avatar
Epilepsy
For the reverse light, it's probably the "reverse switch" on the trans. Besides that I'm not much help, don't know a lot about transmission internals. Sorry.
Old Jul 15, 2008 | 04:33 AM
jal301's Avatar
ANTI-REPUBLICAN
sounds like too much speed shifting.......time for a rebuild / new tranny.....
Old Jul 15, 2008 | 06:56 AM
oh really yeah though so nah i my car wasnt even on so thats the trippy part just though theres somthing i could do to fix it
Old Jul 15, 2008 | 03:02 PM
jal301's Avatar
ANTI-REPUBLICAN
first off, obviously this is only speculation and a suggestion since i do not claim to be any kind of an expert on your situation.........
so ok, you're not even running......you could try getting somebody to rock your car back and forth while trying to move it in and out of gear while pressing the clutch the whole time - get creative and try some different things while somebody is has shifted your car to the front or to the rear. sounds as though there is weight/pressure on the trans as if the car is sitting on a hill and the transmission is stuck in some funky position.
are you parked on a hill or any kind of grade? if so, have your friend try pushing in that direction while you move the shifter around. if that doesn't work, try pushing it towards the other direction.
you could also try jacking the rear up off of the ground in order to get the pressure off of the transmission. then shift it the transmission around to see if you can get it to pop out of the position that it is stuck in. try rotating the rear wheels / drive shaft to see if that helps to get it out of that position. again, get creative.
Old Jul 17, 2008 | 03:52 PM
hmm ill try that today uhh yeah my car is on a slight hill... i know that was detaled but if you can get more in to it it would help because i really want to get this running
Old Jul 17, 2008 | 06:02 PM
uh tryed it never work out to well still the same i mean my car starts like a champ but it doesn not have any gears above 2nd uhh started it to day reverse lights still the same
