Power FC Power FC setting to account for blow-off's
I am just posting this now because another person I know is having this issue. After installing all block off's after 4,000rpm there is 0psi. Boost from 3,000rpm is 10psi but then when it comes to the transition point no boost at all.
Is there a setting in Power FC that should be used to correct for block off's or this is only a mechanical issue. Hoses are brand new Viton w/ simplification as per www.fd3s.net.
Please list all block-off plates you installed, and we will go from there.
But truefully at this time, I believe you hosed something in the process.
First check you map sesnor hose and TPS connector.
Maybe you messed up part of the turbo control system as you loose boost around the switch over point.
Trending Topics
yeah sounds like something in the rats nest, rather then a PFC setting. You do have the sequential turbo setting on. correct? Did the car run correctly after the vacuum simplification or were all these things done at once?
streetlegal?
Mar 17, 2022 02:46 PM
rx8volks
Canadian Forum
Aug 11, 2015 10:30 PM
