AirPump and Throttle Body connectors
Old May 2, 2002 | 01:10 PM
Jedon's Avatar
Slave2TheFD
Almost done with engine install, just a few loose ends:
1. Where does the Airpump electrical connector connect to?
2. Where does the water to cool the tthrottle body come from?
Pics here:
http://www.nopro.com/~jedon/engine/morehelp.html
Thanx!!
Old May 2, 2002 | 01:52 PM
amp's Avatar
amp
old yella
1. remove the vacuum chamber..you should be able to see the emission harness...you should find two extra connectors that does not plug into any of the solenoids...the blue is for the EGR and the other for the A/P
2. if i remember correctly (no reference - took the truck today) this one should be self explanatory...trace hard piping with a rubber hose connected to it located under the UIM next to the firewall...this is your coolant line that runs into the throttle body....if your having problems locating it and you already have coolant in your system....squeeze a coolant line and trace the spill from that area..
Old May 2, 2002 | 01:57 PM
Jedon's Avatar
Slave2TheFD
Thanx amp!
No coolent yet, but now I know where to look for stuff.
-Jedon
