ECU Recommend for Triple Rotor Single Turbo
Old May 2, 2002 | 12:10 PM
PeteCowie's Avatar
Can anyone recommend the best ECU for a triple rotor single turbo FD, also a Web Address, phone number cos I'm in the UK.....
Thanks
Pete Cowie
Old May 2, 2002 | 12:26 PM
Evil Aviator's Avatar
Rotorhead
Re: ECU Recommend for Triple Rotor Single Turbo
Thanks
Pete Cowie
The Motec M4 series will work, but the M-800 is better. Here is the web site and contact list for the UK:
http://www.motec.com.au/uk.htm
This is a diagram showing the required components. Note that this is a racing setup which does not have split trailing ignition for reduced emissions.
http://www.motec.com.au/drawings/m16.pdf
Old May 5, 2002 | 08:14 AM
RICE RACING's Avatar
Multiple Crane Hi6 CDI boxes on the leading plugs will give you better than split timing at revs below 3000rpm that will clear up your emmisions.
A solution to non split for low rev emmisions, Multi spark Capacitive discharge is a hell of a lot better than old tech transistor ignition.
sherff
Feb 24, 2019 12:09 PM
armans
Aug 15, 2015 09:08 PM
