Sponsored by: CARiD
tricky trans question...
Old Jun 11, 2008 | 01:29 AM
sen2two's Avatar
Rx2 > FD
im planning on using a 2ng gen trans (non turbo) in a 1st gen with a renesis.
now the question is, what flywheel/clutch/pressure plate to use?
i have been told the renesis uses TII style clutch. so could i just change to the FC non turbo flywheel/clutch/pressure plate?
Old Jun 11, 2008 | 05:43 PM
gracer7-rx7's Avatar
needs more track time
Check out Mazdatrix's site or give them a call. I believe the 8 uses the same flywheel as the FD and potentially FC Turbo. Given that, you should then be able to use a RX8 clutch or any other as they don't seem to be very different.
rxlevi7
Sep 26, 2015 07:28 AM
