18X8.5 +45 and 18X9.5 +55
Old May 29, 2008 | 10:06 PM
Rookie84's Avatar
Will it work on the FD? The tires sizes are 225/40/18 and 265/35/18. Someone is selling a used set for a great deal, so I'm thinking about picking it up if it fits. I'm concerned about the rear offset being too high... Thanks in advance.
Old May 30, 2008 | 01:21 AM
njstreetrx7's Avatar
should fit well but i would get a half inch spacer just incase for "the look"
Old May 30, 2008 | 01:32 AM
Rookie84's Avatar
Thanks. What is the thickest spacer I can use in the rear without having to install longer studs?
Old May 30, 2008 | 08:10 AM
ptrhahn's Avatar
I use a 5mm spacer at the rear for my track wheels, and the first time I did I ruined two studs. I got a set of new lug nuts with an extended shank that go about 3/8" into the lug hole past the acorn... problem solved. No long studs.
That rear might rub the trailing arm, especially if it's the stock one.
Old May 30, 2008 | 04:17 PM
Rookie84's Avatar
The lug nuts are great idea. Where can I get them?
