what is wrong:(((??
Old May 17, 2008 | 10:27 AM
sickboy2345's Avatar
what is wrong:(((??
hi there
i don't know what just happened, haven't been driving my car for a week, had to sort some things out, i had to replace:
radiator and hoses, eliminated ast, changed bottom crankshaft pulleys, replaced power steering pump tank, front shock absorber,brake pads, and drive belt(done some interior stuff as well but i don't think this is related to my problem)
basically i have just refilled my cooling system, started the engine for first 30 seconds there was a white smoke coming out my exhaust pipe(i think that was because i haven't been driving it but i dont know) then it was ok, engine sounds bit different then before i replaced those things. basically i want to accelerate and when i put my foot down car starts choking and loosing revs(well it sounds like it) i looked under the bonnet whilst engine was running and asked my m ate to press acceleration , same thing but i have noticed that air pump pulley, stops spinning when i accelerate. dont know but i got some weirid feeling that this is because i have done something to them pulleys but i don't know what
the other thing is, when i was replacing the power steering tank i had to unplug the cable at the back of the p/s pump and when i was doing it cable just snapped(well it's still in one piece but i heard it)
this is the cable i'm talking about(does it have something to do with those power looses?
please...i want to start driving my car...
Old May 17, 2008 | 10:37 AM
dhays's Avatar
Is this the cable you are referring to?
Attached Thumbnails what is wrong:(((??-cable.jpg
Old May 17, 2008 | 12:01 PM
no mate this cable:
it just snapped right next to the plug, but i dont even know what this cable does...
Old May 17, 2008 | 12:10 PM
4CN A1R's Avatar
sleeper
if your airpump isnt working, your car could be running too rich at idol...causing it to idol unsteady. are you saying the belt doesnt have proper tension or what? did you get the right size belt? its really important since the water pump pully is on the same belt...
Old May 17, 2008 | 12:20 PM
airpump is working, it spins but when i accelerate it stops spinning, i think the belt has got the right tension, its not too tight and not too loose, everything works ok until i accelerate..
and yes i got the right belt, i went to halfords and they have found the right one for the car i have got..
Old May 17, 2008 | 12:24 PM
Six Rotors's Avatar
Looks like the metering oil pump wires and connector--if there is a broken wire your engine wii be in "limp" mode.
Old May 17, 2008 | 01:04 PM
where do i get the wire from then? is it difficult to replace? where does it go? what do i need to take out to replace it? i need to give it a go..
Old May 17, 2008 | 02:49 PM
Six Rotors's Avatar
There is a 'sticky'at the top of this section called Tech Manual Directory,click on it,then on the first link.there you will find the Factory Service manual for a 1993 RX7.Section D p14 gives you the trouble shooting procedure for the electrical side of the MOP.check Section C for getting at the MOP.
Old May 17, 2008 | 03:06 PM
i have got the manual, checked it already, but there is nothing about where this wire goes, if i need to replace it i need to know(and first, need to find a new wire )
Old May 17, 2008 | 07:26 PM
troberts289's Avatar
Bad white smoke
Hello. I have an 81 rx7. I had just replaced the old intake and carb with an RB 4bbl intake and a holley carb. I had got it to start. But it smokes white smoke. And bad. I didnt bother hooking up the oil lines Just to get it fired. I just mixed in some Marvel Mystery oil in the gas tank.. I may have used a bit much. But im really hoping that coolant isnt finding its way into the engine somehow.
Old May 18, 2008 | 07:00 AM
ok i have checked MOP wire and plug, theinsulation was snapped, not a cable, what i did was i have cleaned the wires and plug and then i put some insulation tape around every single wire with broken insulation(was 3 of them) then i have taped it all up with a new tape, looked ok to me, i have cleaned the plug as well
(one thing i wasn't sure about is :there was no pin in the socket (just one)
i dont know if iit ok but this is how it looks now.
i have started the engine but it was still the same engine doesn't sound like it works properly, it's like something was breaking up...when i started the engine i looke at the hand brake light and it was kinda flashing, not all the time but i took it like the car wasn't getting enough power or something(i tried to video it but when i was recording, the light stayed stabil), i pressed acceleration and car started to choke again...i have recorded a video so you can hear the engine
http://www.youtube.com/watch?v=xmOdWjzMjcM
any ideas??
i was messing up with the interior, is it possibl;e that i have done something to the wiring?
help....
Old May 18, 2008 | 09:58 AM
i have just done ECU reset, still the same
Old May 18, 2008 | 10:03 AM
The Driver's Avatar
Diamond Cut Seven
Kinda stupid but how many miles on the engine - white smoke - engine not sounding right all sound like a seal gone.
Old May 18, 2008 | 10:06 AM
Mahjik's Avatar
Mr. Links
You need to start by checking your engine codes. If you car does not have a Check Engine Light on the dash, follow what you need to do in this link:
https://www.rx7club.com/3rd-gen-archives-73/there-any-chance-read-ecu-codes-without-ecl-238994/
Old May 18, 2008 | 10:32 AM
engine has less the 54k miles, the thing is , that before i ripped all the interior out, even with swapped pulleys,belt etc i have driven it(just to test) then i left it without battery for a week and played with the dashboard. now i got the problem
thx Mahjik i'm gonna try that in a minute...see what happends
Old May 18, 2008 | 12:09 PM
i dont know if i have done it right, i have linked TEN + GND and then connected my multimeter - black rod to b+ , red rod to MEN and nothing happened, then i swapped the rods and still the same ...what should i set my meter to? did i connect it right?
Old May 23, 2008 | 02:23 PM
ok i had to go to the garage, went to Mazda dealer, don't even ask how much they charge p.a but there was no choice. Don't know if you guys interested but just to keep you updated, or maybe someone will have similar problem - it's worth checking.
scar from my invoice:
car is up and running really nice, but i'm bit worried about my turbo.. thinking of taking it back there for more tests.
browntrout
14
May 10, 2015 08:12 AM
texFCturboII
The Bad & Fugly Members
Apr 30, 2013 12:20 AM
jlee916
Nov 24, 2012 03:38 PM
