Crack in Stock IC pipe? (pics)
Old May 12, 2008 | 02:05 PM
dhays's Avatar
I replaced my AST this morning and noticed a crack in the upper IC pipe where it mounts above the coolant fill neck.
Here is a closer view. The crack runs along the mounting tab and pipe body and continue down along the reinforced area for the mounting tab. I'm not sure if this is a full thickness crack or if the IC pipes are connected to the mounting tabs on the bottom and this really isn't a crack at all. Can anyone tell me? BTW, what is the common name for this particular IC pipe?
Old May 12, 2008 | 02:13 PM
Mahjik's Avatar
Mr. Links
That's the crossover pipe for the Y-pipe. The latter RX7's had it changed to a metal pipe:
http://www.rx7store.net/product_p/efiniypipe.htm
Old May 12, 2008 | 02:18 PM
dhays's Avatar
Thanks. Damn that is expensive.
I'll have to look again but I seem to recall that the crossover pipe was a separate piece. I wonder if that can be replaced independently of the Y-pipe?
I'm surprised that the crack hasn't seemed to effect the car's running (at least that I can tell). But then I'm not sure when it cracked. I'll go drive it and see.
Old May 12, 2008 | 02:23 PM
Mahjik's Avatar
Mr. Links
I'm sure Fritz Flynn has plenty of them laying around he would sell for a good price. However, the newer Y-pipe also has improved airflow characteristics which improves performance. Not to mention it removes the use of a coupler on the Y-pipe which is a failure point due to the extreme heat of the turbos. Plus, you could also polish it to make it look shiny:
https://www.rx7club.com/showpost.php...62&postcount=8
So, you could also look for a used newer y-pipe.
Old May 12, 2008 | 02:24 PM
Six Rotors's Avatar
I do not think the pipe is cracked.I think it is the bracket cracking off the pipe--that is what happened to mine.
Old May 12, 2008 | 02:25 PM
Mahjik's Avatar
Mr. Links
Yep, it's hard to tell without having it removed.
Old May 12, 2008 | 02:32 PM
dtn666's Avatar
I don't think that's a crack, there's a groove in the pipe and it fits into the support brace. What I don't see is the top plastic part that goes over the pipe to secure it completely.
Old May 12, 2008 | 02:41 PM
sevensix's Avatar
rotor rotor pow.
like others have said its just that brace thing, those are just snapped onto the crossover
Old May 12, 2008 | 02:43 PM
dhays's Avatar
That is what I was wondering. I'll take it apart and see what's up.
Maybe it is in the same place as my missing ABS heat shield. I wonder how many other pieces I'm missing that I never knew about? BTW, does anyone have a pic of the top plastic piece that secures it?
Old May 12, 2008 | 04:07 PM
Six Rotors's Avatar
I have never seen such a piece.(ie it does not exist!)
Old May 12, 2008 | 04:57 PM
dtn666's Avatar
This is the only picture I've got.
Old May 12, 2008 | 05:16 PM
dhays's Avatar
Yeah. I've not seen Jupiter's moon, Io, either, yet I'm convinced it really does exist.
That is good enough, thanks. It shows me what is missing. The only question would be how important is that at all? The crossover pipe sure doesn't look like it moves around at all. It was rock solid when I removed the lower IC hose from it this morning.
Old May 12, 2008 | 07:58 PM
Six Rotors's Avatar
As you wish.There is none shown for example in the pictures in Yamaguchi's book and there is no such part shown in the Parts Manual.Let me know when you find a part no.
Old May 12, 2008 | 08:18 PM
dhays's Avatar
I'll concede that finding a part number for that would be tough. The more I look at it, the less it looks like it is necessary anyway.
Old May 12, 2008 | 08:25 PM
sevensix's Avatar
rotor rotor pow.
never seen a top strap ever. and yeah neither are needed as far as i know. its probably snapped due to vibration from the engine anyway, better to just let it float.
Old May 12, 2008 | 08:35 PM
adam c's Avatar
Cheap Bastard
There is no top piece to the crossover pipe. It does not exist. The pipe is held in place from the underside.
Old May 12, 2008 | 08:51 PM
Sgtblue's Avatar
Urban Combat Vet
+1.
The strap pictured above is a fabricated piece, likely to cure the situation you have now. IF you need another, I can't imagine they'd be hard to find...and probably for not much more than shipping.
Old May 12, 2008 | 09:22 PM
skir2222's Avatar
I win
I got one if you want it
Old May 12, 2008 | 10:11 PM
dhays's Avatar
I was wondering about that. That was one of the things I asked in my first post:
Thanks for everyones help. I think I'll pull the crossover and take a look at how it is attached. Maybe once I get all the parts I've got laying around (and more coming) I'll see about getting a nice pretty one that Mahjik has.
Old May 13, 2008 | 12:50 AM
j9fd3s's Avatar
Community Builder
thats not correct. they have taken a strap from a broken one and put it on top too
Old May 13, 2008 | 07:07 AM
afterburn27's Avatar
Lets Go Hokies!
Yup, there is no top piece.
To the original thread starter: I have a crossover pipe if you need it, but it looks like the one you have is just fine.
Old May 13, 2008 | 09:44 AM
dhays's Avatar
Yeah, I agree. One of my first guesses seems to be correct than the crossover pipe is connected to the mounting tabs on the bottom. So I'm good!
