Coolingmist controller??
Old May 11, 2008 | 12:58 PM
1wide7's Avatar
I just got my coolingmist vari cool kit installed and the controller seems to be injecting 5 to 7 psi early. I have the min **** set at 17psi just to get it to come on at 10psi on the boost gauge. If i put the min **** at 10 it injects when my boost gauge is reading 5psi, I know there can be a small difference between gauges and computer readings but this seems like alot to be off.
Is there anything that can be done to correct this?
Old May 11, 2008 | 06:26 PM
coolingmist's Avatar
install the software and connect to your laptop. Turn the min **** and look at the **** on the screen. It should match what the controller ***** say, if not, you can remove the green **** and align the **** with the number. Most likely that is your problem.
David
Old May 11, 2008 | 07:33 PM
1wide7's Avatar
Thank you Ill try that and see what happens
Bauer778
Nov 4, 2015 04:42 PM
alexdimen
20
Oct 23, 2015 01:50 PM
frijol
Microtech
Sep 23, 2015 12:51 PM
Heedlessone
Sep 16, 2015 11:31 AM
