FD blues
Old May 9, 2008 | 07:26 PM
rx7rcer09's Avatar
Sir Braps A lot
FD blues
my FD seems to hate cool weather. its like in the low 60's and my car seems to sputter up top. but the other day it was 85 and the car did not sputter any. i ran some stuff called (sea foam) in a tank of gas and i worked wonders on the fuel system i just wondering what could possibly be causing the break up, on the top of the rpms when its cold.?????
Old May 9, 2008 | 10:06 PM
MX722's Avatar
2 Rotors of Fury
I thought sea foam was basically for when the car is in storage, like winters here in the north.
Could be wrong though
Old May 9, 2008 | 10:33 PM
rx7rcer09's Avatar
Sir Braps A lot
its a whole fuel system cleaner and i works good
Old May 9, 2008 | 10:37 PM
Stock ecu?
Old May 9, 2008 | 11:48 PM
Rx72Heaven's Avatar
im thinking your hitting fuel cut, cause the low intake temps causing you to over boost. get a PFC...
Old May 9, 2008 | 11:52 PM
gracer7-rx7's Avatar
needs more track time
Probably is fuel cut. Fix it by controlling your boost (boost controller and run a high flow cat).
Also check out the FAQ thread to learn more about this topic and your car: https://www.rx7club.com/3rd-generation-specific-1993-2002-16/faq-3rd-gen-other-useful-links-68640/
Old May 9, 2008 | 11:59 PM
Rx72Heaven's Avatar
Also Port the waste gate if possible.
dexter snoek
Sep 29, 2015 09:18 AM
