odyssey battery terminal????
Old May 9, 2008 | 02:11 PM
FDSeoul's Avatar
Corea FD
question for those running the odyssey pc680 series battery!
i would like to see picture on how you have the terminal and what kinda after market clamps you have installed.
I am kinda lost on what kinda after market cable clamps i should install on this unit at the terminals ends.
thanks guys!!!
Old May 9, 2008 | 04:07 PM
Smitter's Avatar
94 Single Turbo FD
u can by posts that bolt to the terminals on the battery. then u can use the stock clamps
Old May 9, 2008 | 04:32 PM
DriftDreamzSS's Avatar
Mine came with the posts.
Old May 9, 2008 | 04:43 PM
SLOASFK's Avatar
Top's always down
Odyssey batteries come with different terminal options. Some come with posts, some come with threaded holes, some come with posts with threaded holes. I am running a PC925MJT which has posts with threaded holes. I'm running the stock terminals.
Is a 680 enough to power an FD?
Old May 9, 2008 | 05:49 PM
FDSeoul's Avatar
Corea FD
yes
Old May 9, 2008 | 06:22 PM
Smitter's Avatar
94 Single Turbo FD
the 680 is the battery that Rotary Extreme use to sell in there mini battery kit, to be used with their vmount set ups.
Old May 10, 2008 | 12:12 AM
IRPerformance's Avatar
Sponsor
680s are not really large enough in capacity. Sure the car will run, but if you have any drain in the electrical system it will die. Plus I like to run the fans after shut down. Over my years of working with these cars I got so sick of jumping the cars with the mini batteries. They always die. Get the 925. BTW, the Power FC puts a constant drain on the battery. So do aftermarket alarms or poorly installed stereo systems (90% of the ones I see) Here is how I mount it
Sponsor
Borrowed your car Brian
Old May 10, 2008 | 04:39 AM
FDSeoul's Avatar
Corea FD
Nice
Old May 10, 2008 | 05:17 AM
SLOASFK's Avatar
Top's always down
Originally Posted by SD93FD3S
yes
Smartass
Glad to be the posterboy of IRP
FC3S Timmy
16
Oct 3, 2015 01:08 AM
FC3S Timmy
Oct 2, 2015 08:08 AM
baix2
Power FC Forum
Sep 28, 2015 09:40 AM
Devon Murray
Sep 25, 2015 09:41 AM
