NE RX-7 Forum Serving ME, NH, VT, MA, RI, CT, NY, NJ, DE, PA, OH, WV, MD and VA
flywheel tool
Old May 6, 2008 | 01:37 PM
alwaysjdm's Avatar
Epic Innovations
RI flywheel tool
i was in the middle of replacing the clutch on my 89 and i ran into a problem with the flywheel. it is a massive *** nut. does anyone in the rhode island/mass area have the tool to remove it or a socket that is 54mm or 2 1/8" big. if so would i be able to borrow it for a couple days.
Old May 7, 2008 | 03:06 PM
superchargedrx3's Avatar
Rotor Rican
Yah make sure that you borrow the flywheel stopper tool also makes the job more easier with that nut.
Old May 7, 2008 | 05:02 PM
alwaysjdm's Avatar
Epic Innovations
do you know of a place that i could get both
Old May 7, 2008 | 05:48 PM
Rotor Rican
I picked up my flywheel cup in sears hardware and the stopper on ebay. I just check around and found out that Racingbeat sells both a flywheel stopper and nut wrench for $62.00 plus shipping.To bad your not closer I would let you borrow mines hell I would even give you a hand braking it down. Love working on rotaries especially vintage rotaries. Let me no if this helps you any?
Old May 7, 2008 | 08:09 PM
Mazdax605's Avatar
79 GS,74 RE/PU
I have a socket. I have never needed,or used a flywheel stopper. I live in southeastern MA(Carver to be exact),and I also have the Racing Beat/Mazdatrix pilot bearing removal tool if you need it. Let me know.
Old May 7, 2008 | 08:32 PM
alwaysjdm's Avatar
Epic Innovations
yes it does help because if i cant find anything i will go to sears
Old May 7, 2008 | 08:34 PM
alwaysjdm's Avatar
Epic Innovations
what highway is carver near or you could come and help if u really wanted too. but im getting my flywheel resurfaced.
Old May 7, 2008 | 08:44 PM
Mazdax605's Avatar
79 GS,74 RE/PU
I live not too far off 195/495,and or rt 3. I can help if you need me to,but I am not sure when I will have the time. Married life with two kids doesn't leave a lot of spare time,and I have a wedding,and mothers day this weekend.
Old May 7, 2008 | 08:53 PM
willub and company's Avatar
Pobody's Nerfect
i have the socket, not sure if it's with me or at home.
Old May 8, 2008 | 02:07 PM
alwaysjdm's Avatar
Epic Innovations
yea im gettin all new fluids for it tomorrow and i hope to have the flywheel off to a machine shop on saturday and bolt it up on sunday. willub where is ur home
Old May 8, 2008 | 02:14 PM
Hitokiri_Gensai's Avatar
RHD ftw!
i had to use a 54mm socket and an impact gun from a diesel tech to get the nut off my 13B-RE block. ******* insanity.
torque is something like 330 ft lbs
Old May 8, 2008 | 04:51 PM
alwaysjdm's Avatar
Epic Innovations
yea well if i get a socket i will just use a big *** breaker bar and prevent the flywheel from spinning somehow
Old May 8, 2008 | 05:34 PM
Pobody's Nerfect
home is just north of Worcester mass, school is in RI.
Old May 8, 2008 | 05:45 PM
Mazdax605's Avatar
79 GS,74 RE/PU
I just use a impact wrench,and have never needed a stopper. The impact whacks it at such a high rate that it hardly turns.
Old May 8, 2008 | 05:49 PM
alwaysjdm's Avatar
Epic Innovations
oh then ill try using an impact gun
Old May 8, 2008 | 06:45 PM
Rotor Rican
Impact gun is the way to go. I tried useing a braker bar the fist time I broke one down. It took 2 guys to hold the engine and 2 with a with a pipe with the b bar and brute stength to get it off. Broke the first b bar had to go get another one and then it came off. What a pain in the *** that was never again.
Old May 9, 2008 | 02:20 PM
alwaysjdm's Avatar
Epic Innovations
oh then i will deffinately use the gun.
Old May 11, 2008 | 04:02 PM
alwaysjdm's Avatar
Epic Innovations
i got off the nut with a breaker bar. it was hard but i got it, only to realize the flywheel was pressed on, so now im on the search for a puller.
Old May 11, 2008 | 05:29 PM
Mazdax605's Avatar
79 GS,74 RE/PU
No need for a puller. Just put the nut back on a few threads(so the flywheel doesn't fall on you),and get a BFH(big friggin hammer),and whack the outer edge of the flywheel. Don't hit the face,or the ring gear,but instead a flat portion of the outer edge,and it will rock the flywheel,and it will pop off. I have done it at least 20 times,and it works like a charm. A 2lb sledge works pretty good,but a regular framing hammer not so good. I wouldn't worry about hitting the face by accident if you are having the flywheel resurfaced,but if not make sure you don't hit the mating surface of the flywheel. Good luck,and let us know how you make out.
Old May 12, 2008 | 01:09 PM
alwaysjdm's Avatar
Epic Innovations
oh i didnt know if that would mess up the flywheel or not. i didnt want to risk it. but now i will try it.
LongDuck
Oct 7, 2015 08:12 PM
